jirkaehm
OSPF problem bug/feature/misconfiguration ?
Fri Sep 18, 2009 2:54 pm
Hi all!
I'm having some trouble with OSPF routing.
I have quite simple network see URL: http://jirka.ehm.cz/temp/ospfnetwork.pdf
Router's A, B, C are in area 0.0.0.0 and router A is connected to internet.
Problem is with this topology router B somehow think's that better way for network's in area2 and area 3 is all the way throught area1 router's ( B > R1 > R2> R3 > C ) instead of using simple fast ethernet and go B > C.
I also draw to image OSPF cost's to links between mikrotik's.
So is this a feature or bug or I have something misconfigured?
thank you for any help!
mrz
Re: OSPF problem bug/feature/misconfiguration ?
Fri Sep 18, 2009 3:05 pm
Which version are on those routers?
jirkaehm
Fri Sep 18, 2009 6:14 pm
3.27 on routers ABC and 3.28 on the rest.
Standard routing package
Users browsing this forum: No registered users and 9 guests
