gmsmstr
Trainer
Trainer
OSPF Network with Multiple Default Route Types
Wed Mar 10, 2010 8:28 pm
Can you have a OSPF network, with several routers sending the default routes, but have one primary default route running type 2, and the rest type1. So if the type 2 default route goes down, the network will use the type 1 default routes to route traffic out based on cost, but if that type 2 comes back up, everything will switch to it?
So the question is, can you have both type1 and type2 default routes in one OSPF area?
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
mrz
Re: OSPF Network with Multiple Default Route Types
Thu Mar 11, 2010 8:10 am
Yes you can.
Users browsing this forum: No registered users and 8 guests
