gringoZ
2x parallel vpls tunnel in the same time
Sun Mar 21, 2010 12:17 am
How can i setup rb600 with 2x parallel mpls/vpls tunnel in the same time?
I want bonding vpls1 and vpls2 and bridging with eth at rb600.
vpls1---wlan1 < - - - - - -> wlan1---vpls1
eth <-bri-> bonding rb600 rb600 bonding <-bri-> eth
vpls2---wlan2 < - - - - - -> wlan2---vpls2
I try http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS but without results.
In the same time only one vpls tunnel works...
mishaM
Re: 2x parallel vpls tunnel in the same time
Sat Apr 03, 2010 10:22 pm
good question ! .
mishaM
Sun Apr 04, 2010 7:29 pm
gringo i find way out of a situation .
config set only lsr-id , dont set transport-address .
/mpls ldp
set enabled=yes lsr-id=172.16.0.1 transport-address=172.16.0.1
the rest of configs I think intelligible ;)
-headstrong-
Fri May 07, 2010 9:22 am
MishaM, do you set individual ldp transport address's under /mpls interface?
mishaM
Sat May 08, 2010 6:44 pm
yes i set individual transport address , i tested and that working successful .
so we can setup more 2X parallel vpls tunnel .
for example i have one ap and 3 wlan interface , and i want setup 3 vpls tunnel for bonding
config for AP1 :
add address=172.16.0.1 netmask=255.255.255.252 interface=wlan1
add address=172.16.1.1 netmask=255.255.255.252 interface=wlan2
add address=172.16.2.1 netmask=255.255.255.252 interface=wlan3
/mpls ldp
/mpls ldp interface
add accept-dynamic-neighbors=yes interface=wlan1 transport-address=172.16.0.1
add accept-dynamic-neighbors=yes interface=wlan2 transport-address=172.16.1.1
add accept-dynamic-neighbors=yes interface=wlan3 transport-address=172.16.2.1
/interface vpls
add name=vpls1 remote-peer=172.16.0.2 vpls-id=1:2
add name=vpls2 remote-peer=172.16.1.2 vpls-id=2:2
add name=vpls3 remote-peer=172.16.2.2 vpls-id=3:2
config for AP2 :
/ip address add address=172.16.0.2 netmask=255.255.255.252 interface=wlan1
/ip address add address=172.16.1.2 netmask=255.255.255.252 interface=wlan2
/ip address add address=172.16.2.2 netmask=255.255.255.252 interface=wlan3
/mpls ldp set enabled=yes lsr-id=172.16.0.2
/mpls ldp interface
add accept-dynamic-neighbors=yes interface=wlan1 transport-address=172.16.0.2
add accept-dynamic-neighbors=yes interface=wlan2 transport-address=172.16.1.2
add accept-dynamic-neighbors=yes interface=wlan3 transport-address=172.16.2.2
/interface vpls
add name=vpls1 remote-peer=172.16.0.1 vpls-id=1:2
add name=vpls2 remote-peer=172.16.1.1 vpls-id=2:2
add name=vpls3 remote-peer=172.16.2.1 vpls-id=3:2
-headstrong-
Sat May 08, 2010 8:17 pm
wow ur a genius:P..
what is ur mpls config under /mpls interface?
Do you leave the MTU of all to 1508 ( ie default) or manually set each interface?
mishaM
Sat May 08, 2010 8:49 pm
mtu i set manually 1522 to each interface ;)
-headstrong-
Sun May 09, 2010 7:26 pm
Is it possible to still use the routers lobridge IP for VPLS endpoints if there is no LDP transport address?
mishaM
Sun May 09, 2010 8:55 pm
yes it posible
zgi
Fri May 28, 2010 7:11 pm
What does vpls-id numbers mean? Is the first number, the number of tunnel, and the second number, a number of devices used?
taglio
Tue Aug 03, 2010 5:17 pm
ok..so.. it's seem that this configuration work correctly with mishaM equipment...
Can anyone tell me if have a running link with those specification?!?
In my experience it doesn't work. Simply the vpls2 interface doesn't go up [no running].
I want to bound two vpls interface to obtain the sum of the bandwidth from two 802.11n radios. I want to do this in two x86 machine with two r52n. Link is good and no problem with wifi communication, but when i've to build the software parts of the conf, simply it doesn't work.
This is what i want to do:
####AP1#####
add
/interface vpls
add remote-peer=10.10.3.3 vpls-id=1:2
add remote-peer=10.10.4.3 vpls-id=2:2
/interface bonding
add mode=balance-rr slaves=vpls1,vpls2 transmit-hash-policy=layer-2
add interface=ether1 bridge=bridge1
add interface=bonding1 bridge=bridge1
add address=10.10.3.2/24 interface=wlan1
add address=10.10.4.2/24 interface=wlan2
add address=192.168.1.7/24 interface=ether1
/mpls interface
add interface=all mpls-mtu=1522
/mpls ldp
set lsr-id=10.10.3.2
/mpls ldp interface
add interface=wlan1 transport-address=10.10.3.2
add interface=wlan2 transport-address=10.10.4.2
####AP2#####
add
/interface vpls
add remote-peer=10.10.3.2 vpls-id=1:2
add remote-peer=10.10.4.2 vps-id=2:2
/interface bonding
add address=10.10.3.3/24 interface=wlan1
add address=10.10.4.3/24 interface=wlan2
add address=192.168.1.8/24 interface=ether1
/mpls interface
/mpls ldp
set lsr-id=10.10.3.3
/mpls ldp interface
add interface=wlan1 transport-address=10.10.3.3
add interface=wlan2 transport-address=10.10.4.3
Any suggestions???
.mhavoc world
Fumi
Wed Aug 04, 2010 12:46 pm
I tried this configuration several times and I have not worked!!
I think the bonding can not work with VPLS...
Someone work this type of configuration?
taglio
Thu Aug 05, 2010 11:42 am
Anyone can help us?? Mikrotik support?
.mhavoc world
taglio
Tue Aug 10, 2010 12:20 pm
still no reply- still w8ing for a solution mk support..
.mhavoc world
taglio
Thu Aug 12, 2010 5:12 pm
... simply reply you cannot....or something else.. i've got 3 costumers that 'rew8ing for a solution..
.mhavoc world
MICTD
Thu Aug 19, 2010 2:01 pm
How we can make boundel ( TRUNK ) Two Wireless card N series ( each card has two RF ) and send traffic From Gigabit Ethernet to that boundel ?
Radio A - Ethernet 1 :192.168.0.1 /24
Radio A - WLAN N-series 1: 10.0.1.1 /24
Radio A - WLAN N-series 2: 10.0.2.1 /24
Radio B - Ethernet 1 :192.168.0.2 /24
Radio B - WLAN N-series 1: 10.0.1.2 /24
Radio B - WLAN N-series 2: 10.0.2.2 /24
i use Dual N-stream but CPU usage is going high and it take very low bandwidth , i think the only way is Some routing solution with VPLS .
Please send me Correct solution .
Best regards,
Ali
Users browsing this forum: No registered users and 23 guests
