omidkosari
Trainer
Trainer
VPLS tx error / not Running state
Sat May 29, 2010 2:14 pm
Router1
# may/29/2010 11:57:36 by RouterOS 4.9
# software id = BPHC-897R
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=yes hop-limit=255 loop-detect=no lsr-id=10.51.116.13 \
    path-vector-limit=255 transport-address=10.51.116.13 use-explicit-null=no
/mpls ldp interface
add accept-dynamic-neighbors=yes comment="" disabled=no hello-interval=5s hold-time=15s interface=\
    ether1 transport-address=0.0.0.0
/interface vpls
add advertised-l2mtu=1500 arp=enabled cisco-style=no cisco-style-id=0 comment="" \
    disable-running-check=no disabled=no l2mtu=1500 mac-address=02:BB:E7:6F:13:FB mtu=1500 name=\
    vpls1 pw-type=raw-ethernet remote-peer=10.51.246.2 vpls-id=100:111
/mpls ldp neighbor print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello, V - vpls
 #      TRANSPORT       LOCAL-TRANSPORT PEER                       SEND-TARGETED ADDRESSES
 0 DOTV 10.51.246.2     10.51.116.13    10.51.246.2:0              yes           1.1.1.146
        10.51.246.2
        10.51.246.5
/interface vpls monitor vpls1 once
   remote-label: 45
    local-label: 16
  remote-status:
/interface vpls print
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
 0     name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:BB:E7:6F:13:FB arp=enabled
       disable-running-check=no remote-peer=10.51.246.2 vpls-id=100:111 cisco-style=no
       cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet
Router2
# jan/02/1970 04:54:42 by RouterOS 4.9
# software id = V68Y-G2D0
/mpls
/mpls interface
/mpls ldp
set distribute-for-default-route=no enabled=yes hop-limit=255 loop-detect=no \
    lsr-id=10.51.246.2 path-vector-limit=255 transport-address=10.51.246.2 \
/mpls ldp interface
add accept-dynamic-neighbors=yes comment="" disabled=no hello-interval=5s \
    hold-time=15s interface=ether1 transport-address=0.0.0.0
/interface vpls
add advertised-l2mtu=1500 arp=enabled cisco-style=no cisco-style-id=0 \
    comment="" disable-running-check=no disabled=no l2mtu=1500 mac-address=\
    02:86:A4:FF:27:57 mtu=1500 name=vpls1 pw-type=raw-ethernet remote-peer=\
    10.51.116.13 vpls-id=100:111
V - vpls
 0 DOTV 10.51.116.13    10.51.246.2     10.51.116.13:0             yes
   remote-label: 16
    local-label: 45
  remote-status:
 0     name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:86:A4:FF:27:57
       arp=enabled disable-running-check=no remote-peer=10.51.116.13
       vpls-id=100:111 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500
As you see the state of vpls interface is not running and every packets which should go through vpls , counts Tx error of vpls .
omidkosari
Trainer
Trainer
Re: VPLS tx error / not Running state
Sun May 30, 2010 10:05 am
Router1
/ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   10.51.116.13/24    10.51.116.0     10.51.116.255   ether1
 1   1.1.1.145/30       1.1.1.144       1.1.1.147       vpls1
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 A S  0.0.0.0/0          10.51.116.13    10.51.116.1        1
 1 ADC  1.1.1.144/30       1.1.1.145       vpls1              0
 2 ADC  10.51.116.0/24     10.51.116.13    ether1             0
/mpls ldp interface print
 #   INTERFACE        HELLO-INTERVAL       HOLD-TIME
 0   ether1        5s                   15s
        10.51.246.2
        10.51.246.5
/mpls local-binding print
Flags: X - disabled, A - advertised, D - dynamic, L - local-route, G - gateway-route, e - egress
 #      DST-ADDRESS        LABEL        PEERS
 0 ADLe 10.51.116.0/24     impl-null        10.51.246.2:0
 1 ADG  0.0.0.0/0          impl-null        10.51.246.2:0
 2 ADLe 1.1.1.144/30       impl-null        10.51.246.2:0
/mpls remote-binding print
 #    DST-ADDRESS        NEXTHOP         LABEL        PEER
 0  D 10.51.246.0/30                     impl-null        10.51.246.2:0
 1  D 1.1.1.144/30                       impl-null        10.51.246.2:0
 2  D 0.0.0.0/0                          impl-null        10.51.246.2:0
 3  D 10.51.246.4/30                     impl-null        10.51.246.2:0
 4  D 10.0.0.0/8                         84        10.51.246.2:0
Router2
/ip address print
 0   10.51.246.2/30     10.51.246.0     10.51.246.3     ether1
 1   10.51.246.5/30     10.51.246.4     10.51.246.7     ether2
 2   1.1.1.146/30       1.1.1.144       1.1.1.147       vpls1
/ip route print
 0 A S  0.0.0.0/0          10.51.246.2     10.51.246.1        1
 1 ADC  1.1.1.144/30       1.1.1.146       vpls1              0
 2 A S  10.0.0.0/8         10.51.246.2     10.51.246.1        1
 3 ADC  10.51.246.0/30     10.51.246.2     ether1             0
 4 ADC  10.51.246.4/30     10.51.246.5     bridge1     0
 0   ether1        5s                   15s
 0 DOTV 10.51.116.13    10.51.246.2     10.51.116.13:0             yes           1.1.1.145
        10.51.116.13
 0 ADLe 10.51.246.0/30     impl-null        10.51.116.13:0
 1 ADLe 1.1.1.144/30       impl-null        10.51.116.13:0
 2 ADG  0.0.0.0/0          impl-null        10.51.116.13:0
 3 ADLe 10.51.246.4/30     impl-null        10.51.116.13:0
 4 ADG  10.0.0.0/8         84        10.51.116.13:0
 0  D 10.51.116.0/24                     impl-null        10.51.116.13:0
 1  D 0.0.0.0/0                          impl-null        10.51.116.13:0
 2  D 1.1.1.144/30                       impl-null        10.51.116.13:0
omidkosari
Trainer
Trainer
Mon May 31, 2010 10:30 am
Any idea ? Does informations incomplete ?
omidkosari
Trainer
Trainer
Tue Jun 01, 2010 9:53 am
Bump
omidkosari
Trainer
Trainer
Wed Jun 02, 2010 8:47 am
Is it so hard problem ? anybody heard something about VPLS ? :-x
Mplsguy
Wed Jun 02, 2010 4:16 pm
From your config I understand that your VPLS endpoints are not on the same subnet (are not directly connected). In order for such a tunnel to work you need MPLS LSP between both endpoints that would transport VPLS packets. There clearly is no such LSP in your setup, because the only LDP neighbour you have is remote VPLS peer. So as minimum you must enable LDP on all routers between VPLS endpoints.
I suggest you carefully study MPLS/VPLS related docs here:
http://wiki.mikrotik.com/wiki/MPLS
anpena
Thu Jul 12, 2012 4:47 pm
Hello Mplsguy
Just want to ask similar question related with this configuration reported above, In my understanding is possible to transport VPLS using BGP and L2vpn to transport the VPLS information and create dynamic VPLS tunnels, in the above scenario where network is not continuos and crossing multiple IP backbone routers Non-MPLS could be possible to set such VPLS and have it running state? I tried such configuration, have VPLS Tunnels stablished dynamically created and BGP signaled but not running state as well; there is anyway to make this works over the IP backbone? I know this RFC4364 mentioned the possibility and I know Mikrotik support it.
I followed below instructions where LDP is no needed because BGP L2VPN family does the transport:
http://wiki.mikrotik.com/wiki/BGP_based_VPLS
Thank you!
Users browsing this forum: No registered users and 10 guests
