StubArea51
Trainer
Trainer
Re: IPv6 recursive nexthops via iBGP
Thu Mar 03, 2016 3:50 pm
@paoloaga and @nz_monkey
Same boat here.....we've gotten by with peering on the subnet instead of on a /128 loopback until it's fixed. We have a ton of customer IPv6 migrations we are working on that need this since the IPv4 topology is recursion based with BGP and OSPF.
RouterOS v7 #thelongwait :shock:
ZeroByte
Thu Mar 03, 2016 10:44 pm
I keep expecting to see this every time there's a new MUM....
There's so much that's been promised in ROSv7.
StubArea51
Trainer
Trainer
Thu Mar 03, 2016 10:49 pm
Maybe we'll get lucky and it will be Dallas in a month and a half :-)
nz_monkey
Sat Mar 05, 2016 12:20 am
It is no trivial task developing a new routing engine, adding major new features and testing all the corner cases, all the while maintaining the existing code base and back porting drivers so you can release new hardware.
I'm sure Mikrotik are just as desperate as we are to get v7 out, so they can focus on one code base and a newer kernel.
Dallas does seem to be the likely place we will see v7 announced [WHITE SMILING FACE]
paoloaga
Re:
Sun Mar 06, 2016 10:38 am
What we are asking is not an exotic feature, it's basic IPv6 functionality...
ZeroByte
Re: Re:
Sun Mar 06, 2016 4:51 pm
Monkey's statement was directed at the comments on here hoping that ROSv7 should come out soon, and how long it's been said by Mikrotik that "such-and-such a feature will be in next version of ROS" What he was referring to is the fact that they're apparently re-writing the routing engine for ROSv7....
I've found several "misbehaviors" of ROS in both OSPF and BGP that are about this same level - they don't stop the system from being a viable platform for routing, but a few common "best practice" designs are broken due to these oddities. (The one which irritates me most is how a backup OSPF default-gw router won't drop its announcement if the original default-gw is also an OSPF route.)
mrz
Thu Mar 10, 2016 2:20 pm
v7 Teaser alert, recursive ipv6 works :D
[admin@tested] > /routing/route/print
Flags: D - dynamic, X - disabled, I - inactive, A - active,
C - connect, S - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, Y - synthetic, T - terminal,
> - best, ' - candidate, U - updated, F - filtered
        DST-ADDRESS        GATEWAY            DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
 AS >'   0.0.0.0/0          10.5.130.1                1    30           10 10.5.130.1%ether1
DAC >'   10.5.130.0/24      ether1                    0    10              ether1
 AS >'   ;;; router-test
        2001:2001::/64     fe80::29:dfff:f...        1    15           10 fe80::29:dfff:fe2b:14d0%ether2
        2001:2002::/64     2001:2001::1              1    30           15 fe80::29:dfff:fe2b:14d0%ether2
hedele
Thu Mar 10, 2016 2:27 pm
ooops.. looks like CLI will change a lot?
Chupaka
Thu Mar 10, 2016 3:57 pm
and the very first v7 bug report :D a typo: should be 'connected', I think :)
patrick7
Thu Mar 10, 2016 5:53 pm
@mrz More informations about v7 please :D Even it would be a fully broken beta, I'd be happy to see the news ;-)
nz_monkey
Fri Mar 11, 2016 12:34 am
What I see, I like :)
Particularly the "> - best, ' - candidate, U - updated, F - filtered " feature. This will save us a lot of troubleshooting time.
paoloaga
Fri Mar 11, 2016 5:49 pm
Wonderful news. Hope we can play with it very soon.
Now there is another question that bugs my mind: if the CLI syntax is new, I will have to refactor all the automated software (and it is complex!): Is it possible to access to an early documentation or have an early version to install on a lab box so we can start working on the management software and have it ready for when v7 will be released???
ZeroByte
Fri Mar 11, 2016 5:57 pm
I noticed that too - if the command syntax requires slashes now, that's a huge change that will require everyone to modify their scripts and so forth. Hopefully they're going to go through a deprecation period where older syntax is still supported but gives deprecation warnings if you use it in an interactive shell, or something like that. I don't personally use scripts much, but many do. I wonder how that's going to unfold.
Chupaka
Fri Mar 11, 2016 10:02 pm
I can't see any reason to use slashes instead of spaces, moreover slash has different positions on different keyboards — I don't believe they will change current command style...
nz_monkey
Sat Mar 12, 2016 2:17 am
Mikrotik have used this different CLI syntax in previous early test releases for new systems.
I don't think what is shown above will be in the final release.
StubArea51
Trainer
Trainer
Tue Mar 15, 2016 3:22 pm
Well that's good because my brain can't digest yet another CLI syntax without imploding. On a daily basis, I'm already juggling Cisco [IOS, NX-OS, ASA and Wireless Controller], Juniper, HP, Dell, ZyXEL, AdTran, IBM, Lenovo, etc...as well as MikroTik.
#nonewcli :-)
mrz
Fri Mar 18, 2016 1:58 am
Old menu without slashes will be available, so scripts will not break.
nz_monkey
Fri Mar 18, 2016 7:30 am
Thanks for the confirmation Maris.
Chupaka
Fri Mar 18, 2016 11:21 am
Just available? So, new style will stay here in release version? %)
hknet
Sun Aug 07, 2016 6:30 pm
after reading this thread I'm still trying to make sense, so I conclude:
OSPFv3 and Loopback-bridge-interfaces with /128 IPv6 addresses assigned in RouterOS will only be shown reachable if one sets an admin-mac to the bridge (named eg Loopback0).
well, that's not 100% intuitive, but I guess that's something I can live with.
to receive those Looback IPs (/128) via OSPFv3 one has to remove the LA bit somehow (simple workaround suggested by MikroTik is to simply import those Loopback IPs as external routes), well this is also not perfectly straight forward, but one can work with this.
but on the iBGP case I read something about setting static routes on the RouterOS side to make the connection to Loopback IPs of other iBGP speakers...
well, tried that, but I'm with no luck in getting any routes received from a routereflector installed as active.
currently tested with RouterOS v6.36
any advice greatly appreciated :)
savage
Thu May 25, 2017 12:59 am
7 years later, and still not fixed :roll:
Thank you MT. You pretty much put the final nail in the coffin as far as using Mikrotik goes. I (like many others), can not continue to wait 'indefinitely' until the mythical v7 finally appears.
savage
Thu May 25, 2017 1:01 am
What you perhaps don't know, and can't live with... If Loopback0 (in your example) is in a VRF for IPv4, IPv6 won't work completely. The connected route never becomes active, and OSPF never injects the route - ANOTHER MT bug...
guilhermeramires
Trainer
Trainer
Tue Aug 29, 2017 4:18 pm
Use ULAs instead of LL. No need to use filters or static this way.
ZeroByte
Tue Aug 29, 2017 4:55 pm
And how exactly does one cause OSPFv3 to use ULAs as the next hop address instead of LL addresses?
If it takes work-arounds to use ULAs, you may as well use the global-unique (public) addresses instead of having a third layer on there.
hknet
Tue Aug 29, 2017 5:39 pm
Hi
saw this thread reactivated :)
The only workaround we have seen so far for iBGP IPv6 routes to get active is to add a static ipv6 route for the loopback IP for the next-hop delivered through the route-reflectors.
(again tested with RouterOS 6.40.2)
If there is any workaround, I'd be glad to hear about it.
Dear MikroTik it would be nice to know how static routes work in this case and how eg. ospfv3 routes fail or maybe there is the possibility for a script run every 30 seconds or so to get the /128 routes (probably loopbacks) out of the ospfv3 table and into static routes and cleaning up those routes that were lost since the last run. I'm not savvy enough in terms of MikroTik scripting to come up with a script that does that.
thx
hk
JimmyNyholm
Sun Sep 03, 2017 1:31 pm
Hi. RR's need not to be in data path (most often aren't) so please consider your own setup before fiddeling with above statement.
@Mikrotik please fix IPV6 it is 2017 after all and Ipv4 is getting more and more expensive.
hknet
Sun Sep 03, 2017 3:03 pm
ahem, the nexthop delivered by RRs was not implying the nexthop in fact is the RR, in fact the nexthop is usually the IP set by "next-hop self" (or similar) by BGP-routers talking to the RRs, but as long as those next-hop IPs are delivered via ospf (which is pretty common imho) routes are not getting active, therefore static routes to those IPs set by BGP-routers as "next hop" are the only workaround I'm aware of, but I'd be happy to hear any other solution.
Regards
hk
JimmyNyholm
Sun Sep 03, 2017 8:39 pm
Regards
hk
"Nexthop self" in an bgp environment is an abomination. I agree that it has some good corner cases but a good setup IGP for distributing nexthops (ie: ospf with loopbacks) and a non nexthop modifying ebgp and ibgp. Depending on number of routers you have fullmesh ibgp is fast responsive but explodes in management if you are constantly growing. This is where clustered RR's is a must to keep peering sessions manageable. It's in this space I just claimed that a RR is most of the time not in the packets Datapath and it need/should not to be it should only RR your network.
Having Mikrotiks they can not be pure reflecting as they only reflect active routes. This is a limitation on the MT but then again the good IGP takes care of this even here. The request for being true RR mode has been asked here before and we are told to expect that in the unicorn version 7.
I think that we speak of the same thing but may from different perspective.
As for IPV6 my statement is even more clear from my perspective. MT Please fix IPV6.
Yours J
hknet
Sun Sep 03, 2017 9:17 pm
Well
It should not be needed - agreed, but real world teaches us:
One looses an external interface and therefore the nexthop is removed from the IGP.
In a small network this converges fast and causes virtually no service disruption.
Think about lots of BGP-peers and lots (fulltable times N) of routes all handled with policies and communities and so on.
IGP (eg. ospf) still converges within seconds and removes the route to the previously valid next-hop.
Now all BGP-routes that learned these routes have to reevaluate their situation on where to go next. If you loose say 500k routes from this single event this can take a moment, packets are still forwarded to the now unreachable next-hop and get lost.
Here a forward to a still existing loopback-IP is a much less disruptive solution: packets are still forwarded to the loopback, but the router owning it knows its interface is down and can decide where to go next with those packets as it has probably already marked all routes for removal that were formerly learned from this external peer. You may see some funny packetflows, but usually don't loose as much packets.
Cheers,
hk
wsftech
Thu Sep 07, 2017 9:40 am
Hi
hk
Let me recap, and please correct me if I'm wrong.
1. Under no circumstances does ROS6 recursively resolve BGP IPv6 routes using link-local addresses; or OSPF-populated loopback IPs using either link-local, ULA, or static ('public') IPv6 addresses
2. ROS can resolve IPv6 routes that recurse to *static* routes with appropriate scope/target scope values.
3. It is impossible to use a modern network design of OSPF-populated loopbacks and multihop BGP peering for IPv6 routes.
4. We are stuck in the dark ages of static addressing.
I've tested this on 6.38 and 6.39, and I can only assume from this thread that <6.41 doesn't fix this either.
I assume that one could simulate an OSPF-like failover behavior by using multiple static routes, ping gateway, and distance, but yuck!
Is the only alternative for, say, IGP, to use OSPF only?
ZeroByte
Thu Sep 07, 2017 5:43 pm
Pretty much correct.
For those following along at home, here is a summary of the issue:
OSPFv3 installs the link-local address of its neighbor as the next-hop address when it places routes into the routing table.
eBGP will use the peer's address as the next-hop. Note that this is directly-attached eBGP peering (which is the standard methodology)
iBGP preserves the next hop address of the prefixes shared.
example:
Two EBGP neighbors link up over a /126 connection (2001:db8:ffff::0/124 with the external peer being ::1
The local EBGP router learns 2001:db8:cafe::/48 via 2001:db8:ffff::1 and installs this into the local routing table. Everything is a-okay so far.
There is some arbitrary topology within the local ASN.
Somewhere inside the ASN is an iBGP peer of the EBGP border router.
The BGP strategy is to use the IGP (OSPF in this case) to determine the best next hop for reaching the egress point chosen by BGP.
So in the RIB (live routing table), the next hop will be the OSPF-determined best next hop to reach the peering address.
Since OSPFv3 uses link-local, this is where the problem comes from.
example:
So the iBGP peer has some set of paths to reach the eBGP router above.
The eBGP router will also be advertising its peering link into the local IGP (ospf) so that other routers will know how to reach this peering point.
So 2001:db8:ffff::/0 will be in the OSPF database.
the iBGP router will have a route with dst=2001:db8:ffff::/0 gateway=fe80::abcd -- where fe80::abcd%ether1 is the link-local IPv6 address of the OSPF neighbor through which the best path leads.
The iBGP router learns prefix 2001:db8:cafe::/48 from the eBGP router. The next hop for this prefix will be 2001:db8:ffff::1
The iBGP router must now perform a recursive lookup on 2001:db8:ffff::1 in order to set the next-hop for 2001:db8:cafe::/48
In ROS, this is where the problem happens because the next hop is going to be fe80::abcd%ether1. The iBGP recursive lookup bug prevents this route from being installed as an active route in the routing table. The work-around is to use a static route to reach 2001:db8:ffff::/124 where the next hop address is not a link-local address.
e.g. if the router with link-local address fe80::abcd%eth1 is also using 2001:db8:beef::1 as a global public address on the link to iBGP router, then on iBGP router would need a static route as follows:
dst=2001:db8:ffff::/124 gateway=2001:db8:beef::1
This is obviously quite problematic.
Apparently the root cause is something deep enough in the routing engine code that Mikrotik has stated this will only be fixed in RouterOS v7
In a nutshell, it is impossible to deploy a standard OSPF+iBGP ASN for IPv6 using Mikrotik. If your network does not use iBGP, then you can use IPv6 in your core w/o worrying about this issue.
You may be able to make a work-around with GRE tunnels directly between all bgp-speaking routers and some next-hop-self tweaks, but this seems very undesirable to me as well.
wsftech
Fri Sep 08, 2017 2:58 am
ZeroByte, thanks for the detailed comments.
After further testing, I have reached the same conclusions you have. I would rather not tunnel — although I did briefly contemplate a full-mesh MPLS/VPLS for directly peering each IPv6 router. (Traffic queue management would be just one problem with that design.)
I settled on sticking with OSPFv3, as that at least works, and can use link-local, so not actually very painful to implement. In addition I found out today that my upstream provider (a publicly traded company) also uses OSPFv3 as IGP, and they're a Juniper shop… go figure.
For eBGP, no problem is encountered, as next-hops are rewritten anyway upon further route advertisement.
<sigh>
aplvmn
Sun Sep 24, 2017 7:53 pm
I just started deploying IPv6 and found this issue, going over this post made me feel disappointed, I think I have spent money for nothing on this boxes, I have found so many bugs with other technologies in MK (Radius, PPP, and an endless list), I guess that is why is so cheap compared to Cisco or Juniper.
SplitHorizon
Thu Oct 05, 2017 10:46 am
Just marking the register on this issue.. it has caused me enough grief..
patrick7
Thu Oct 05, 2017 12:28 pm
I think there will be no fix in the near future.
zimage
Thu Oct 05, 2017 6:05 pm
I gave up on mikrotik when we moved to a dual stack network because of this bug. You can find new Juniper SRX routers pretty cheaply if you look hard. Don’t pay more than 25% of the list cost, though.
savage
Thu Oct 05, 2017 7:09 pm
I'm in the same boat. Can't use MT in my core / borders. MT is definitely not aware of the actual seriousness of this issue, especially on larger networks.
There's actually PLENTY of IPv6 broken, especially on the PPP side (filters, address-lists, IP assignments, the list goes on). BGP not working, is a HUGE issue.
JimmyNyholm
Fri Aug 24, 2018 8:46 pm
Passing Into Late 2018 And still this is big issue when @Mikrotik WHEN will recursive routing work in routeros. Installed V6 routes that have reachables nexthops (recursivly that is) will never be active due to something broken. FIX NOW. IPV4 days are over and we must deploy ipv6.
StubArea51
Trainer
Trainer
Wed Aug 29, 2018 6:25 pm
We could really use an update on this MikroTik. :-)
We are seeing IPv6 adoption move at a much faster pace in 2018 and are having to modify the routing architecture or use other brand routers for our clients to solve this problem.
This has been an issue for a long time but we could really use a fix
patrick7
Wed Aug 29, 2018 6:55 pm
@IPANetEngineer If it would be important for them, they would have fixed this issue years ago.
Just proceed with FRRouting :-) It's better anyways.
StubArea51
Trainer
Trainer
Wed Aug 29, 2018 7:48 pm
Depends on your use case. I like FRR and talk to a number of the developers at FRR on a regular basis. However, it's still software that's go to go on bare metal or a VM and there are a number of operational challenges with that if you're doing something outside of BGP Full table or RR.
Would really just like to see this fixed. :-)
wsftech
Wed Aug 29, 2018 7:52 pm
It's not possible to use Mikrotik in a real production-quality dual-stack service provider network without working BGP.
I'd hate to see the CCR series, for example, be left out in the cold, if we have to wait for an entirely new generation of hardware to get ROS7. Not to spread FUD, but I don't have much to go on.
sep
Thu Sep 20, 2018 11:25 pm
is there any updates on this incredibly critical part of the puzzle ? is there no other option that just avoiding using mikrotik for routing ?
there is nothing we deployed without ipv6 nowadays. But plenty that we deploy as ipv6 only. and CCR would be a excellent fit is so many cases.
but this is a brick wall show stopper for mikrotik.
kind regards
Ronny Aasen
bbs2web
Sat Sep 22, 2018 11:07 pm
Getting decent IPv4 performance without packet loss on CCR routers has required us to use raw firewall rules to stop connection tracking on forwarded traffic and building a distributed core network where P routers talk only IPv4 OSPF and PE routers exchange routes via BGP route reflectors so that they reference the remote router's loopback IP. This way traffic ingressing at a PE router will be switched to the destination router via MPLS.
IPv6 OSPFv3 is reported as being the culprit but without IPv6 MPLS support we would be back at P routers having to route each packet. Setting up a BGP signaled VPLS using split horizon bridging allows one to set the bridge protocol mode to none, whilst avoiding bridging loops. We then assigned IPv6 /128 loopback IPs and assigned the same IP with a /64 subnet to the VPLS bridge interfaces.
Is my thinking in this regard wrong or is the IPv6 routing problem on RouterOS actually a recursive routing issue at heart?
Topology:
Summary:
  • IPv4 OSPF with MPLS using loopback IPs, where only the default gateway is redistributed on R1
  • RR1 has two IPv4 BGP sessions to R1 and R5. RR1 reflects routes and both R1 and R5 set the nexthop as their loopback interface IPs
  • BGP peering sessions are running with IPv4, IPv6 and L2VPN address families
  • Everything establishes without errors and I can ping from the test PC connected to R5 to 8.8.8.8 using IPv4 (MPLS switched through R4, R3 and R2)
  • I can ping IPv6 gateways and routes appear to install correctly but I can not ping remote IPv6 addresses
R1:
R5:
Configuration:
R1:
add name=bridge-ipv6-mpls protocol-mode=none
add name=lo
set [ find default-name=ether2 ] mtu=2026
/routing bgp instance
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.1
/routing ospf instance
set [ find default=yes ] distribute-default=if-installed-as-type-1 router-id=10.0.0.1
/interface vpls bgp-vpls
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1
add address=10.0.0.1 interface=lo
add address=172.16.254.5/30 interface=ether2
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ipv6 address
add address=2001:db8::1/128 advertise=no interface=lo
add address=2001:db8:1000::1/48 advertise=no interface=ether1
add address=2001:db8::1 advertise=no interface=bridge-ipv6-mpls
/mpls interface
set [ find default=yes ] mpls-mtu=1992
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.1 transport-address=10.0.0.1
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether2
/mpls local-bindings
add label=impl-null
/routing bgp peer
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=RR1 nexthop-choice=force-self remote-address=10.0.0.6 remote-as=65530 ttl=default update-source=lo
/routing ospf interface
add authentication=md5 authentication-key=PHi02OnUPN1gzENt dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
/routing ospf network
add area=backbone network=10.0.0.1/32
add area=backbone network=172.16.254.4/30
/system identity
set name=R1
R2:
add name=lo
set [ find default-name=ether1 ] mtu=2026
set [ find default=yes ] router-id=10.0.0.2
add address=10.0.0.2 interface=lo
add address=172.16.254.9/30 interface=ether1
add address=172.16.254.6/30 interface=ether2
set servers=1.1.1.1,1.0.0.1
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.2 transport-address=10.0.0.2
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether1
add authentication=md5 authentication-key=3r5MTWTfAD4dDMeH dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add area=backbone network=10.0.0.2/32
add area=backbone network=172.16.254.8/30
/system identity
set name=R2
R3:
add name=lo
set [ find default-name=ether3 ] mtu=2026
set [ find default=yes ] router-id=10.0.0.3
add address=10.0.0.3 interface=lo
add address=172.16.254.13/30 interface=ether2
add address=172.16.254.10/30 interface=ether1
add address=172.16.254.21/30 interface=ether3
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.3 transport-address=10.0.0.3
/mpls ldp interface
add hello-interval=1s hold-time=10s interface=ether3
add authentication=md5 authentication-key=ZxOnGXB2ZLsCr0dJ dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
add authentication=md5 authentication-key=5bnwqgfAomwbU9B3 dead-interval=10s hello-interval=1s interface=ether3 network-type=point-to-point
add area=backbone network=10.0.0.3/32
add area=backbone network=172.16.254.12/30
add area=backbone network=172.16.254.20/30
/system identity
set name=R3
R4:
add name=lo
set [ find default=yes ] router-id=10.0.0.4
add address=10.0.0.4 interface=lo
add address=172.16.254.17/30 interface=ether2
add address=172.16.254.14/30 interface=ether1
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.4 transport-address=10.0.0.4
/mpls ldp interface
add authentication=md5 authentication-key=ZxOnGXB2ZLsCr0dJ dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add authentication=md5 authentication-key=A54RUkZukh3lDRBb dead-interval=10s hello-interval=1s interface=ether2 network-type=point-to-point
add area=backbone network=10.0.0.4/32
add area=backbone network=172.16.254.16/30
/system identity
set name=R4
R5:
add name=lo
add name=DHCP ranges=192.168.248.50-192.168.248.199
add address-pool=DHCP disabled=no interface=ether1 lease-time=12h name=ether1
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.5
set [ find default=yes ] router-id=10.0.0.5
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1 site-id=5
add address=10.0.0.5 interface=lo
add address=172.16.254.18/30 interface=ether2
add address=192.168.248.1/24 interface=ether1
add address=192.168.248.0/24 gateway=192.168.248.1
/ipv6 address
add address=2001:db8::5/128 advertise=no interface=lo
add address=2001:db8:5000::1/48 advertise=no interface=ether1
add address=2001:db8::5 advertise=no interface=bridge-ipv6-mpls
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.5 transport-address=10.0.0.5
/mpls ldp interface
/routing bgp peer
add area=backbone network=10.0.0.5/32
/system identity
set name=R5
RR1:
add name=lo
set default redistribute-connected=yes redistribute-static=yes router-id=10.0.0.6
set [ find default=yes ] router-id=10.0.0.6
add bridge=bridge-ipv6-mpls bridge-horizon=1 export-route-targets=1:1 import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1 site-id=6
add address=10.0.0.6 interface=lo
add address=172.16.254.22/30 interface=ether1
/ipv6 address
add address=2001:db8::6/128 advertise=no interface=lo
add address=2001:db8::6 advertise=no interface=bridge-ipv6-mpls
/mpls interface
/mpls ldp
set distribute-for-default-route=yes enabled=yes lsr-id=10.0.0.6 transport-address=10.0.0.6
/mpls ldp interface
/routing bgp peer
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=R1 remote-address=10.0.0.1 remote-as=65530 route-reflect=yes ttl=default
add address-families=ip,ipv6,l2vpn in-filter=bgp-in multihop=yes name=R5 remote-address=10.0.0.5 remote-as=65530 route-reflect=yes ttl=default
add authentication=md5 authentication-key=5bnwqgfAomwbU9B3 dead-interval=10s hello-interval=1s interface=ether1 network-type=point-to-point
add area=backbone network=10.0.0.6/32
/system identity
set name=RR1
mducharme
Trainer
Trainer
Sun Sep 23, 2018 12:07 am
I'm guessing that might be the cause of your issue. Use different IPs with a /64 subnet for the VPLS bridge interfaces than you are using for the loopback. I expect the ping above would then work.
bbs2web
Sun Sep 23, 2018 6:59 am
The point is to get IPv6 ingressing at a PE switched across P routers using MPLS. You also missed the fact that I can ping R5's IPv6 loopback from R1 and vice versa, so the gateways are reachable.
mducharme
Trainer
Trainer
Sun Sep 23, 2018 7:06 am
I did not miss this, I can see quite well that the gateways are reachable. We offer IPv6 over VPLS tunnels and it works quite well. But given the routing tables you have shown, there is no other reason I can see (short of a bug) why the ping would fail. I expect that the duplication of IPs from the loopback to the VPLS bridge interface is not impacting the direct ping, but may be preventing the recursive routing from functioning properly. For instance, your routing tables show that the nexthop for 2001:db8::1 is 2001:db8::1, the nexthop for 2001:db8::5 is 2001:db8::5, and the nexthop for 2001:db8::6 is 2001:db8::6. This would seem to me to create a loop that can not be recovered from, hence not being reachable when it comes to recursive routing, but reachable when it comes to a direct ping response.
bbs2web
Sun Sep 23, 2018 8:28 am
IPv6 appears extremely unreliable in the GNS3 virtual lab I put together. The following initially only worked in one direction (R1 -> R5) until I restarted R5, after which it worked in both.
Added IPv6 prefix filter to the route reflector (RR1):
/routing filter add chain=bgp-in address-family=ipv6 prefix=2001:db8::/64 prefix-length=64-128 action=discard
/routing filter add chain=bgp-out address-family=ipv6 prefix=2001:db8::/64 prefix-length=64-128 action=discard
/routing bgp peer set [ find ] in-filter=bgp-in out-filter=bgp-out
R1:
R5:
mducharme
Trainer
Trainer
Sun Sep 23, 2018 8:39 am
Again, what I see here as a common link is that you are assigning the same IPv6 address to the loopback interface as a /128 as you are to the VPLS interface (/64). I strongly suspect that this is the cause of your issues.
I have found that RouterOS does not always treat interfaces properly with IPv6. For instance, if two OSPFv3 neighbors share the same link local address (even though their interface IDs are different), the OSPFv3 process will get confused and not allow one of the two neighbors to become an OSPFv3 neighbor.
bbs2web
Sun Sep 23, 2018 9:37 am
My intention with this lab exercise was to find a solution to efficiently switch IPv6 packets between provider edge (PE) routers R1 and R5, through an IPv4 MPLS core, using iBGP. RouterOS 6.43.2 can not be used to recursively resolve IPv6 iBGP nexthop using OSPFv3 and running OSPFv3 without IPv6 MPLS in the core is not optimal anyway and would unnecessarily duplicate administrative work. The lab essentially attempts to emulates Cisco 6PE where IPv6 PE routers communicate with each other over an IPv4 MPLS core.
Routing lookups should reference the best match so 2001:db8::5 from R1 matches the 2001:db8::/64 route referencing the BGP signaled VPLS bridge interface and transmit it out there. RouterOS is Linux based so all IPs are present in table 255 without a netmask, which is hard coded as the first lookup rule when processing sent or received packets. One can run 'ip rule list; ip route show table 255' on any Linux system to observe this behaviour (the same reason why RouterOS can not fully isolate VRFs).
The environment does now appear to be working consistently, the problem was due to IPv6 addresses associated with the VPLS bridge interfaces having been set as 'advertise=no'. 2nd amendment to the lab environment:
R1 + R5 + RR1:
/ipv6 address set [ find interface=bridge-ipv6-mpls ] advertise=yes
Edit: This was working randomly, see further comment.
You mention having numerous production networks doing just this, I have no production experience and would appreciate it if you would be so kind as to share your knowledge in this regard.
mducharme
Trainer
Trainer
Mon Sep 24, 2018 10:34 am
R1 + R5 + RR1:
Strange - advertise=yes shouldn't make a difference, you should not need router advertisements for this to work. They must be somehow working around an underlying issue.
I didn't quite say that. I said we offer IPv6 over VPLS tunnels, but there is no BGP involved in the way we provision services - we bridge the customer at one end to a VPLS tunnel, and the other end of the tunnel has their gateway IP bound. We do L2VPN, not L3VPN.
bbs2web
Tue Sep 25, 2018 1:44 am
As you state the advertise option is not needed and was most probably only effecting a change by it flapping the IPv6 address when applying the change. Problem resurfaces if the layer 2 VPLS tunnels re-establish and automatically get removed and added to the bridge, thereby changing its MAC address. I assume a deeper bug relating to the link local address not updating properly to track the interface's MAC so I simply set a static MAC address on the 'bridge-ipv6-mpls' interfaces to avoid the quirk.
Recap:
  • Set static MAC addresses on 'bridge-ipv6-mpls', as detailed below
R1:
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:01
R5:
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:05
RR1:
/interface bridge set [ find name=bridge-ipv6-mpls ] auto-mac=no admin-mac=00:14:F2:00:00:06
R1 + R5 + RR1:
mducharme
Trainer
Trainer
Tue Sep 25, 2018 1:52 am
Yes, I have seen issues like this as well. In cases where a port leaves a bridge with auto-mac and rejoins, the link local shown in IPv6->Addresses doesn't always match the link-local that the router responds on, which leads to all kinds of other issues. Setting an admin MAC is the safest workaround.
MasterJames
Wed Apr 03, 2019 3:29 pm
I think this is still not right in 6.44.1 the date is 2019:04:03 feels like a really bad April fools joke?!
Maybe this problem I am having is unrelated but similar.
viewtopic.php?f=2&t=147216
I think this thread is ten years old!? this can't still be waiting for version 7 can it?
liteforce
Wed Apr 03, 2019 6:02 pm
Original poster here :D
I am both shocked and amazed that this issue is still present in current day RouterOS v6.44.1 even though I reported it back in the days of RouterOS v4.x.
Regards,
Terry Froy
Spilsby Internet Solutions
hknet
Wed Apr 03, 2019 8:59 pm
#funfact a little over three years ago we were teased about the working solution with ROSv7 and we were shown a printout on how it behaves, but that's about it I guess...
actually I guess that's one main reason we use MTs for layer2-setups and as CPEs, the core is and probably will be junipers and ciscos for the foreseeable future :)
timoid
Wed Apr 03, 2019 11:25 pm
MT need to rebrand: "Routing the legacy world"
bbs2web
Thu Apr 11, 2019 1:03 am
We've been running IPv6 since September last year without issues. Multiprotocol IPv4 BGP sessions set next hop as the router's loopback IPv4 or IPv6 addresses and IPv6 is MPLS switched between routers, avoiding route lookups at each hop. Core routers don't run BGP, only IPv4 with MPLS so reconvergence is quick.
Recap:
paoloaga
Mon Jul 29, 2019 1:49 pm
Maybe it could help in a few small cases...
viewtopic.php?f=9&t=150616&p=742085#p742085
doof
Tue Aug 17, 2021 10:38 am
This bug still seems to be present in 6.48.3.
mrz
Tue Aug 17, 2021 10:40 am
This feature is added in ROS v7, v6 will stay as it is.
Users browsing this forum: No registered users and 10 guests
