name29
BGP Backup
Sun Jun 20, 2010 10:36 pm
Hi!
I have a problem.
I'm an AS internet provider and i have my public IPs.
I have two internet "backbone" and i can use my public IPs on these two.
But i have to use the first's backbone only for a range of my IPs ( from 1 to 100 ) and use the second's for the other IP ( from 101 to 254 ).
I have a routed network with ospf for "intra-routing" and BGP for routing with the other AS.
I have a router that divide my network from the two backbone and i use policy routing for choose the correct. I have some other router from this gateway and the other provider.
Now i have to make an automatic system for route to the available backbone if one of this go down.
Thank's
Chupaka
Re: BGP Backup
Tue Jun 22, 2010 8:07 pm
so, does that setup work, or you just use policy routing for upload traffic, but download comes via one of your ISPs?..
what's your current config?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
name29
Re: BGP Backup
Tue Jun 22, 2010 11:09 pm
I try to explane :-D
My network use OSPF
MY_NET ( OSPF ) <-> CORE ROUTER ( OSPF ) <-> ROUTER1(OSPF) <-> BGP1_ROUTER ( OSPF & BGP )
MY_NET ( OSPF ) <-> CORE ROUTER ( OSPF ) <-> ROUTER2(OSPF) <-> BGP2_ROUTER ( OSPF & BGP )
So i like that my ip from .1 to .100 are annunciated on internet from the BGP1_ROUTER and my ip from .101 to .254 on the BGP2_ROUTER. This for upload and for download.But if the BGP1_ROUTER is unreacheble (or BGP2_ROUTER) i like that the first range ( .1 to .100 ) are annunciated from the BGP2_ROUTER.
(BGP1_ROUTER and BGP2_ROUTER are connected to internet by two different provider)
(Sorry for my bad english :-D )
Chupaka
Re: BGP Backup
Tue Jun 22, 2010 11:53 pm
you should use routing filters to announce backup routes with some prepend - so they will be used only when main route is off
name29
Re: BGP Backup
Wed Jun 23, 2010 10:51 am
can you explane my how to made it ?
I have to use a script to disable the routing filter ?
MichelePietravalle
Trainer
Trainer
Re: BGP Backup
Wed Jun 23, 2010 12:27 pm
do you have only a /24? in this case is difficult to announce only half to one ISP and the other half on the other, becouse prefix< 24 are filtered and dropped!!
if you have a /23 or >, you can split the announcement and announce the full /23 on both isp and a /24 for ISP; in this way the /24 is smaller and have precedence; if the isp will fall down, the /24 will not be announced and the whole /23 take priority!
this is the simple way!
for outgoing traffic you can use the route marking!
Michele P
name29
Re: BGP Backup
Wed Jun 23, 2010 12:38 pm
Michele P
But this on the core router or on the two BGP routers?
Chupaka
Re: BGP Backup
Thu Dec 12, 2013 11:43 am
on your BGP routers (BTW, why two?.. one is enough...)
just decide exactly what you want to do
Last bumped by name29 on Thu Dec 12, 2013 11:43 am.
Users browsing this forum: Majestic-12 [Bot] and 8 guests
