trouble
vpls issue-tunnel is up but no data transfer
Tue Jun 29, 2010 11:43 am
with following scenario , i am not able to transfer data but vpls tunnel is up , but i can transfer data if create eoip tunnel , sending host says host unreachable , ...any help would be appreciated.
host a----ether---router a--->wlan<-----wlan<---router b--->wlan----wlan<--router c--ether--host b
but if use following scenario no issue
host a --ether--router a--->wlan----wlan<---routerb---ether--host b
i played little bit with mtu but no success.
i am using routeros 4.9
regards
bafh
Re: vpls issue-tunnel is up but no data transfer
Tue Jun 29, 2010 11:45 am
wlan or vlan or WAN?
anyway - routes.
trouble
Tue Jun 29, 2010 11:55 am
wan interface are wlan ...
trouble
Tue Jun 29, 2010 7:43 pm
could you please explain it little bit , to avoid bridging i m using vpls , if u have any current config then please share with me .
Mplsguy
Tue Jun 29, 2010 11:15 pm
It seems you do not have proper MPLS LSP established between VPLS endpoints (I guess so because it works when endpoints are directly attached). Make sure that you have LDP or TE properly configured on all 3 routers. In case you are still having problems, post MPLS related configuration here.
trouble
Thu Jul 01, 2010 4:41 am
Thanks Staff ..problem is solved, it was configuration issue as you said.
Users browsing this forum: No registered users and 18 guests
