bda
How to inject default route to some vrf and adv. to peers?
Sat Sep 04, 2010 8:16 pm
Dear developers... How to inject default route to some vrf to advertise it to peers in this vrf? Simply adding "default originate" do nothing... Is it possible at all?
God bless UNIX!
blake
Re: How to inject default route to some vrf and adv. to peer
Sat Sep 04, 2010 10:39 pm
Did you try this?
/routing bgp peer refresh-all
IT consultant. Network manager. Packet junkie.
1-928-328-1509
bda
Sat Sep 04, 2010 11:29 pm
Did you try this?
Of course!
God bless UNIX!
bda
Sun Sep 05, 2010 1:10 am
Solved.
peer set default-originate=always rtr11
do the trick. Winbox only have default originate checkbox, and has no menu in which we can select options...
UPDATE. pls, can anybody describe, why after peer restart - the default-originate=always reset to if-installed?
God bless UNIX!
blake
Sun Sep 05, 2010 7:23 am
Solved.
do the trick.
So, Winbox defaults to if-installed when you check default-originate? Interesting. When you said you had default-originate turned on I assumed you were using the option always.
I prefer the command line due to these types of inconsistencies.
1-928-328-1509
bda
Sun Sep 05, 2010 11:46 am
Solved.
do the trick.
Yes, the CLI - is great, but why default-originate resetting after session restart? Maybe dev. team help?
God bless UNIX!
bda
Tue Sep 07, 2010 6:25 am
Dear developers, is it right to reset peer parameter default-originate=always to default-originate=if-installed , after peer restart via winbox? Pls help...
God bless UNIX!
mrz
Tue Sep 07, 2010 8:08 am
This option is not up to date in winbox. Use CLI to set default-originate=always and nothing will be reset unless you open peer config in winbox and make any changes then default-originate will be set to winbox defaults.
bda
Tue Sep 07, 2010 10:26 am
Ok, thanks.
God bless UNIX!
Users browsing this forum: No registered users and 3 guests
