kdavid
RB 1100 Full BGP throughput.
Sun Feb 13, 2011 2:52 pm
is anyone using MK RB 1100 or 1000 rog full bgp routing? I am interested in maximum throughput.Will be possible route around 600-700 Mb/s?
Second question:
Is anyone using mikrotik OS on PC for full bgp routing?
Thanx,
dav
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB 1100 Full BGP throughput.
Sun Feb 13, 2011 5:34 pm
Second question:
Thanx,
dav
Based on customer feedback, I think the RB1100 should be good for about 200Mbps. I would recommend something with 3GHz or faster dual core Pentium for your requirements.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
kdavid
Sun Feb 13, 2011 8:38 pm
Thanx for your answer.
Is this kind of solutionstable? 3 GHz Quad core xenon CPU for around 800 - 900 Mbit/s FULL BGP routing with 2 upstream providers?
How much memory is required for this kind of solution?
Second question:
Thanx,
dav
Tom
rodolfo
Long time Member
Long time Member
Sun Feb 13, 2011 9:00 pm
I use an rb1000 with 1GBram and two full bgp table; they use 640MB of ram.
It route 100Mbit (connection tracking activated) and 20% of cpu.
rodolfo
IZ0UQV
kdavid
Sun Feb 13, 2011 9:31 pm
Is it stable please?
My biggest problem right now are rules in our peering cente. We MUST use only CISCO. I dont understand why. But if i compare the price of MK based HP server and cisco 7201 it is horrible. :shock:
Thanx anyone
rodolfo
Long time Member
Long time Member
Mon Feb 14, 2011 11:05 pm
very stable:
also, read this: http://forum.mikrotik.com/viewtopic.php?f=2&t=49180
rodolfo
IZ0UQV
wpeople
Tue Apr 12, 2011 4:27 pm
currently i don't use RB's for BGP, but i've just tested the RB1100AH units.
1GHz CPU speed ~980mbps routing (conntrack off)
1GHz CPU speed ~700mbps routing (conntrack on) 710/11mbps, 62k/22k pps
1.5GHz CPU speed ~1.2Gbps mbps routing (conntrack off) 970/300mbps, 93k/43k pps
Tested with jperf, windows default (maybe 1500byte frames) 100 and 200 paralell connections
Cpu is ~90-95%
I know it not answers Your question, but offer a useful info.
nany
Sat Jul 09, 2011 2:53 pm
Cpu is ~90-95%
i have a question for you, how did you make conntrack off,
please reply as soon as possible, because i need the solution urgently
Jeeves
Wed Jul 13, 2011 6:18 pm
I've tested the RB1100 with a two full feeds for some time. But the CPU load was about 80-100% percent in my case. I switched to a x86-box, which works fine. (Celeron @3Ghz IIRC). So I'd advise you to get a x86 box.
wpeople
Wed Jul 13, 2011 7:17 pm
nany:
in cli: ip firewall connection tracking set enabled (or disabled)
faisali
Wed Jul 27, 2011 5:38 pm
FYI... with ver 5.x if you have winbox open to the router, while doing BGP updates, the cpu utiliation shoots up high, and accepting routes takes a lot longer...
(BUG with WINBOX ?)
Close Winbox, use SSH or even the Webfig interface..
We see this behavior on x86 boxes as well.
Users browsing this forum: No registered users and 15 guests
