arthurmitch
ftp port fowading
Tue Jul 26, 2011 10:46 am
ok i have the following problem on my network i cannot connect to my ftp using my command prompt but i can connect using my gui windows based internet explorer,if got ospf setted up on all 7 of my routers,i can connect and enter username and password but the error i get when connecting throw my command prompt when doing ls like list directorys is:
500 illegal port command
425 unable to build data connection; operation timed out
aney ideas?
janisk
Re: ftp port fowading
Tue Jul 26, 2011 3:37 pm
that means that related data connection cannot be created. check if you have nat somewhere in the middle and nat helper is disabled, or you have to switch to passive mode, if you are not already using that.
arthurmitch
Tue Jul 26, 2011 4:48 pm
where do i disable nat helper?
fewi
Tue Jul 26, 2011 6:18 pm
http://wiki.mikrotik.com/wiki/Manual:IP ... vice_Ports
But you want the helper ENABLED on all routers that do NAT. Not that you should be doing NAT on more than one router (the border router where traffic from your AS exits to the Internet).
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
dasiu
Trainer
Trainer
Tue Jul 26, 2011 6:20 pm
/ip firewall service-port
But I think that janisk was asking to check if it is not disabled somewhere - it should be enabled for active FTP connection to be established ;-).
edit: Yeah, fewi was faster :).
arthurmitch
Wed Jul 27, 2011 9:49 am
ok i already did that thought it was something else i will build a diagram and paste it now
arthurmitch
Wed Jul 27, 2011 1:43 pm
ok here is my main router: rout print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 41.134.110.9 1
1 A S 10.0.0.0/24 192.168.45.3 110
2 A S 10.1.1.0/24 192.168.45.3 110
3 ADC 41.134.110.0/28 41.134.110.10 ether1 0
4 A S 192.168.11.0/24 192.168.45.3 110
5 ADC 192.168.13.0/24 192.168.13.1 bridge1 0
6 A S 192.168.20.0/24 192.168.45.3 110
7 A S 192.168.30.0/24 192.168.45.3 110
8 ADC 192.168.45.0/24 192.168.45.1 ether5 0
9 A S 192.168.50.0/24 192.168.45.3 110
10 A S 192.168.88.0/24 192.168.45.3 110
firewall:
0 ;;; All-Internet
chain=srcnat action=masquerade out-interface=ether1
1 ;;; Loop-Back
chain=srcnat action=masquerade protocol=tcp src-address=192.168.45.0/24 dst-address=192.168.88.2
2 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=20-25 protocol=tcp dst-address=41.134.110.1 dst-port=20-25
3 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=443 protocol=tcp dst-address=41.134.110.1 dst-port=443
4 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=2040-2050 protocol=tcp dst-address=41.134.110.1 dst-port=2040-2050
5 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6080 protocol=tcp dst-address=41.134.110.1 dst-port=6080
6 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=9091 protocol=tcp dst-address=41.134.110.1 dst-port=9091
7 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=80-81 protocol=tcp dst-address=41.134.110.1 dst-port=80-81
8 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=3203-3206 protocol=tcp dst-address=41.134.110.1 dst-port=3203-3206
9 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=5900-5935 protocol=tcp dst-address=41.134.110.1 dst-port=5900-5935
10 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6000-6020 protocol=tcp dst-address=41.134.110.1 dst-port=6000-6020
11 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=6080 protocol=tcp dst-address=41.134.110.1 dst-port=6080
12 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=7000 protocol=tcp dst-address=41.134.110.1 dst-port=7000
13 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8061 protocol=tcp dst-address=41.134.110.1 dst-port=8061
14 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=8080-8082 protocol=tcp dst-address=41.134.110.1 dst-port=8080-8082
15 chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=9091 protocol=tcp dst-address=41.134.110.1 dst-port=9091
16 chain=dstnat action=dst-nat to-addresses=10.1.1.2 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8292
17 chain=dstnat action=dst-nat to-addresses=10.1.1.1 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8293
18 chain=dstnat action=dst-nat to-addresses=192.168.20.1 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8294
19 chain=dstnat action=dst-nat to-addresses=10.0.0.2 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8295
20 chain=dstnat action=dst-nat to-addresses=10.0.0.1 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8296
21 chain=dstnat action=dst-nat to-addresses=192.168.50.2 to-ports=8291 protocol=tcp dst-address=41.134.110.1 dst-port=8297
-- [Q quit|D dump|down]
router 2:
0 A S 0.0.0.0/0 192.168.45.1 1
1 A S 10.0.0.0/24 10.1.1.1 110
2 ADC 10.1.1.0/24 10.1.1.2 wlan1 0
3 A S 41.134.110.0/28 192.168.45.1 110
4 A S 192.168.11.0/24 10.1.1.1 110
5 A S 192.168.13.0/24 192.168.45.1 110
6 A S 192.168.20.0/24 10.1.1.1 110
7 A S 192.168.30.0/24 10.1.1.1 110
8 ADC 192.168.45.0/24 192.168.45.3 ether1 0
9 A S 192.168.50.0/24 10.1.1.1 110
10 A S 192.168.88.0/24 10.1.1.1 110
firewall:
0 chain=srcnat action=masquerade
router 3:
0 A S 0.0.0.0/0 10.1.1.2 1
1 A S 10.0.0.0/24 192.168.20.1 110
2 ADC 10.1.1.0/24 10.1.1.1 wlan1 0
3 A S 41.134.110.0/28 10.1.1.2 110
4 A S 192.168.11.0/24 192.168.20.1 110
5 A S 192.168.13.0/24 10.1.1.2 110
6 ADC 192.168.20.0/24 192.168.20.2 ether1 0
7 A S 192.168.30.0/24 192.168.20.1 110
8 A S 192.168.45.0/24 10.1.1.2 110
9 A S 192.168.50.0/24 192.168.20.1 110
10 A S 192.168.88.0/24 192.168.20.1 110
firewall:
router 4:
0 A S 0.0.0.0/0 192.168.20.1 192.168.20.2 1
1 A S 10.0.0.0/24 192.168.30.2 110
2 A S 10.1.1.0/24 192.168.20.2 110
3 A S 41.134.110.0/28 192.168.20.2 110
4 ADC 192.168.11.0/24 192.168.11.1 ether3 0
5 A S 192.168.13.0/24 192.168.20.2 110
6 ADC 192.168.20.0/24 192.168.20.1 ether2 0
7 ADC 192.168.30.0/24 192.168.30.1 ether1 0
8 A S 192.168.45.0/24 192.168.20.2 110
9 A S 192.168.50.0/24 192.168.30.2 110
10 A S 192.168.88.0/24 192.168.30.2 110
firewall:
router 5:
0 A S 0.0.0.0/0 192.168.30.1 1
1 ADC 10.0.0.0/24 10.0.0.2 wlan1 0
2 A S 10.1.1.0/24 192.168.30.1 110
3 A S 41.134.110.0/28 192.168.30.1 110
4 A S 192.168.11.0/24 192.168.30.1 110
5 A S 192.168.13.0/24 192.168.30.1 110
6 A S 192.168.20.0/24 192.168.30.1 110
7 ADC 192.168.30.0/24 192.168.30.2 ether1 0
8 A S 192.168.45.0/24 192.168.30.1 110
9 A S 192.168.50.0/24 10.0.0.1 110
10 A S 192.168.88.0/24 10.0.0.1 110
firewall:
router 6:
0 A S 0.0.0.0/0 10.0.0.2 1
1 ADC 10.0.0.0/24 10.0.0.1 wlan1 0
2 A S 10.1.1.0/24 10.0.0.2 110
3 A S 41.134.110.0/28 10.0.0.2 110
4 A S 192.168.11.0/24 10.0.0.2 110
5 A S 192.168.13.0/24 10.0.0.2 110
6 A S 192.168.20.0/24 10.0.0.2 110
7 A S 192.168.30.0/24 10.0.0.2 110
8 A S 192.168.45.0/24 10.0.0.2 110
9 ADC 192.168.50.0/24 192.168.50.1 ether1 0
10 A S 192.168.88.0/24 192.168.50.2 110
firewall:
router 7: this was my main router but is now the las router that is onsite.
0 X S 0.0.0.0/0 41.134.110.2 1
1 X S 0.0.0.0/0 196.212.100.145 1
2 A S 0.0.0.0/0 192.168.50.1 1
3 A S 0.0.0.0/0 192.168.50.1 1
4 X S 0.0.0.0/0 196.212.100.145 2
5 X S 0.0.0.0/0 41.134.110.2 3
6 A S 10.0.0.0/24 192.168.50.1 110
7 A S 10.1.1.0/24 192.168.50.1 110
8 A S 41.134.110.0/28 192.168.50.1 110
9 A S 192.168.11.0/24 192.168.50.1 110
10 A S 192.168.13.0/24 192.168.50.1 110
11 A S 192.168.20.0/24 192.168.50.1 110
12 A S 192.168.30.0/24 192.168.50.1 110
13 A S 192.168.45.0/24 192.168.50.1 110
14 ADC 192.168.50.0/24 192.168.50.2 ether3-wirless 0
15 ADC 192.168.88.0/24 192.168.88.1 ether5-lan 0
firewall:
that last router router7 was my main router atleast untill they stole my dsl cables so now i had to get a new connection to my home and my ftp is on 192.168.88.2.
arthurmitch
Tue Aug 30, 2011 9:26 am
found my trouble and sortede it out thanx in anyway!
Users browsing this forum: No registered users and 8 guests
