norpan
DHCP-relay in MPLS VRF
Tue Dec 13, 2011 11:53 pm
Hi all!
I'm trying to setup a dhcp-relay which should relay requests through a L3 MPLS-VPN but can't get it to work.
It seems like the relay request are sent via the main routing-table (default gw) and not the vrf.
I'll try to illustrate:
[DHCP server (192.168.88.1)] --vrf1-- [PE1] ---MPLS Cloud (main)--- [PE2] --vrf1-- [DHCP Client]
PE2 has dhcp-relay setup: (ether1=main, ether2=vrf1)
/ip dhcp-relay add delay-threshold=none dhcp-server=192.168.88.1 disabled=no interface=ether2 local-address=192.168.92.2 name=relay1
When I sniff at PE2 on ether1 I see DHCP unicast IP-packet and not a MPLS-encapsulated packet.
Anyone got an idea about this? Limitation?
mrz
Re: DHCP-relay in MPLS VRF
Wed Dec 14, 2011 9:36 am
DHCP relay is not VRF aware, so it is not going to work.
norpan
Wed Dec 14, 2011 8:40 pm
Ok, thanks.
norpan
Mon Dec 19, 2011 12:56 pm
After some time considering this, any plans to implement?
Would be nice to have. :)
andersm
Fri Mar 07, 2014 2:19 am
Hey,
I have come across the same dilemma...
Trying to relay DHCP over a routed MPLS network, from a windows DHCP server, to clients on VRF's across a WAN.
Is there any fix to this? Seems to work fine on Cisco hardware, just stumped on the Mikrotiks.
Cheers,
Andy
norpan
Sat Mar 08, 2014 6:13 pm
I was able to do a workaround with one mangle and one nat rule to make this work.
Make you sure you have a route for the DHCP server in the main table, default route is enough (or else the router will drop the packet) and create a mangle rule kind of like this:
ip firewall mangle add chain=output  dst-address=<dhcpserver> protocol=udp dst-port-67 action=mark-routing new-routing-mark=<vrf>
Possible you need a nat rule to make sure the source address is correct for the customers network:
ip firewall nat add chain=srcnat dst-address=<dhcpserver> protocol=udp dst-port=67 routing-mark=<vrf> action=src-nat to-addresses=<relayip>
relayip is the address you have assigned on the interface facing the customers network.
Hope this helps.
andersm
Tue Mar 11, 2014 8:26 am
Thanks heaps norpan,
worked perfectly! Didn't need the nat rule it seemed.
Now I can get things rolling! :D
Users browsing this forum: No registered users and 14 guests
