Is the above correct, or is there a way to have a router redistribute arbitrary routes (say, redistributing static) where one route will be redistributed with cost 10 and one will be redistributed with cost 50?
Edit: to clarify, I'm looking for something along the lines of:
Code: Select all
router ospf 1
redistribute connected subnets route-map control-conn
access-list 1 permit 192.168.100.0 0.0.0.255
route-map control-conn permit 10
match ip address 1
set metric 50
route-map control-conn permit 20
set metric 10
