marcof
OSPFv3 aera other than 0 (backbone) does not work
Thu Dec 22, 2011 6:01 pm
I'm trying to set up ospfv3 between an ROS 5.11 (RB1100) and a Cisco7200 IOS 12.4.24T6 Router. When I use area 0 for the Link everything works fine, but I need to have the link in area 10 because the Cisco router is the ABR and does route summarization / range.
the neighbor adj changes goes through the states and ends up with FULL, DR and BDR are elected. In the cisco log, I see that the LSAs are re transmitted quite often.
cisco show that adj also as FULL:
edge1.bal#sh ipv6 ospf neighbor
Neighbor ID Pri State Dead Time Interface ID Interface
82.117.20.x 1 FULL/DR 00:00:38 19 GigabitEthernet0/1.518
the log on the MT sow this:
04:05:23 route,ospf,warning LSA installation failed
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.3 originator=82.117.20.3 seqnum=0x80000001
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.4 originator=82.117.20.3 seqnum=0x80000001
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.5 originator=82.117.20.3 seqnum=0x80000001
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.6 originator=82.117.20.3 seqnum=0x80000001
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.7 originator=82.117.20.3 seqnum=0x80000001
04:05:23 route,ospf,warning     header=Summary Network LSA id=0.0.0.8 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning LSA installation failed
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.0 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.1 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.2 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.3 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.4 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.5 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.6 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.7 originator=82.117.20.3 seqnum=0x80000001
04:05:28 route,ospf,warning     header=Summary Network LSA id=0.0.0.8 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning LSA installation failed
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.0 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.1 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.2 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.3 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.4 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.5 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.6 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.7 originator=82.117.20.3 seqnum=0x80000001
04:05:33 route,ospf,warning     header=Summary Network LSA id=0.0.0.8 originator=82.117.20.3 seqnum=0x80000001
any ideas, is this known bug? thank you very much in advance for your help!
ludvik
Re: OSPFv3 aera other than 0 (backbone) does not work
Tue Jan 24, 2012 3:46 pm
In Quagga OSPFv3 areas doesn't implemented yet ... In mikrotik probably too.
Users browsing this forum: No registered users and 57 guests
