kellogs
2 peers, 4 /24 prefix and load balance outbound
Thu Dec 29, 2011 3:26 pm
Dear Members
I have 2 Peers each with same amount of transit
I have 4 /24 prefix
I would like to configure that for the 4 prefix outbound, it would be round robin on these 2 peers and if one of the peer is down, all 4 prefixes would switch to the survival peer.
Any help is appreciated
mrz
Re: 2 peers, 4 /24 prefix and load balance outbound
Thu Dec 29, 2011 5:15 pm
In this case you should use policy routing. A lot of examples can be found in wiki.
guilhermeramires
Trainer
Trainer
Fri Dec 30, 2011 6:40 pm
Keep you balance the way you are doing and you also can announce your /22 in both peers. If one peer goes down all traffic will be redirect to the other peer.
Mikrotik Training Partner
MPLS for the Masses
kellogs
Mon Jan 02, 2012 1:56 pm
I have announced both /22 on both peers and also 4 /24 on both peers
For incoming load sharing, each of the 2 /24 prefix has bgp prepend 4 so incoming is shared equally +-
the problem is with outgoing connection which I think i need to do policy routing. I am looking for the right documentation/wiki
anyone can share a link?
Thanks!
guilhermeramires
Trainer
Trainer
Mon Jan 02, 2012 8:35 pm
Upload is really easy. You need to create a ECMP route with check-gateway enabled. Just add both gateways in the same static route. The traffic will be share using round-robin every time source or destine address change. This way you can reach a good balance. Try it and tell us, ok?
MPLS for the Masses
Users browsing this forum: No registered users and 12 guests
