angboontiong
Jumbo frame support...
Thu Jan 19, 2012 12:55 pm
Is anyone got idea, how we can setup the jumbo frame in the RouterOS?
janisk
Re: Jumbo frame support...
Thu Jan 19, 2012 1:06 pm
get rb1100AHx2 and set MTU over 9000, seriously.
just note that you need to have supporting hardware elsewhere to use jumbo frames.
angboontiong
Fri Jan 20, 2012 6:12 pm
Hi Janisk...
you mean we set the value on the ethx > general > mtu?
mrz
Fri Jan 20, 2012 6:14 pm
Yes..
angboontiong
Sat Jan 21, 2012 3:01 am
Yes..
hi, appreciated it.
got a question that, if i ping from the windows command prompt.
if i issue the following command...
ping 192.168.88.1 -t -l 5000, does it mean i am pinging with 5000 size of packet?
if not, how we going to check the packet size flow to the routerboard?
thanks
rodolfo
Long time Member
Long time Member
Sat Jan 21, 2012 2:38 pm
use also -f switch to do not fragment packets
rodolfo
IZ0UQV
blake
Sun Jan 22, 2012 12:05 am
Yes..
It means you are pinging with 5000 bytes of just ICMP payload. Add 8 bytes for the ICMP header, and 20 bytes for the IP header and that'll put you at 5028 bytes. This value of 5028 should not exceed the MTU value set on the router otherwise the packet will not pass.
ping -t -l 5000 -f 192.168.88.1
IT consultant. Network manager. Packet junkie.
1-928-328-1509
Users browsing this forum: Google [Bot] and 4 guests
