mycket
OSPFv3 authentication with cisco
Wed Mar 14, 2012 12:14 pm
Hello everybody,
I try to get ospfv3 authentication between MK and a cisco device to work.
Cisco has this this
area 1 authentication ipsec spi 256 md5 1234
thing. And I can't figure out how to make it on the MK. :(
Anyone has such thing running? Thanks for any hints.
Mycket
vik1988
Re: OSPFv3 authentication with cisco
Fri Mar 16, 2012 7:43 am
Hello everybody,
Cisco has this this
Mycket
I think you can configure OSPF authetication as below
/routing ospf interface
add authentication=md5 authentication-key=1234 authentication-key-id=1 cost=\
10 dead-interval=40s disabled=no hello-interval=10s instance-id=0 \
interface=all network-type=default passive=no priority=1 \
retransmit-interval=5s transmit-delay=1s use-bfd=no
Vikas Kumar Gupta
If you Like my post then add KARMA
skype- kumarvikas_gupta
Azendale
Tue Apr 01, 2014 7:15 pm
retransmit-interval=5s transmit-delay=1s use-bfd=no[/quote]
Isn't that for just OSPF (v2?). He's talking about OSPFv3, ie, IPv6 OSPF. Which from what I've read uses IPsec for athentication?
If you look in the WebUi for a router with the IPv6 plugin, the OSPFv3 page does not show stuff for MD5 athentication where the Plain (IPv4) does.
mrz
Wed Apr 02, 2014 11:08 am
Currently ospfv3 authentication is not implemented.
Majklik
Wed Apr 02, 2014 12:08 pm
The OSPFv3 authentication uses IPsec. If there will be in the IPsec configuraiton option for the manul keying, then can be OSPFv3 secured. It is pity that "/ip ipsec manual-sa" was removed from the RouterOS. But one configuration option under OSPFv3 which create all requisited SPD and SA entries is more comfortable - in this way works the Cisco command "area X authentication ipsec ...".
Or Juniper way is to define the maual SA entry (like was in the ROS: /ip ipsec manual-sa add name=XXX ..." and then under OSPFv3 interface is only something like "set ipsec-sa XXX".
We had too problem with this that was required OSPFv3 authetication in some installations - so was used Juniper boxes and not RBs.
Users browsing this forum: No registered users and 10 guests
