andrijco
How to Copy dynamic Route to another route table
Tue Mar 20, 2012 12:37 pm
Hello i have small problem
i need to have specific routes in separate routing table
> i need to mark routes from one bgp instance
> and give those routes to another bgp instance
> with first routing filter i place all incoming prefixes to "temp"
> routing table
> with second routing filter i need to filter out only routes from temp
> table
> second filter work only when needed prefixes are in main routing table
> but not in temp table
so how to copy routes from temp table to main
tws101
Re: How to Copy dynamic Route to another route table
Tue Mar 20, 2012 4:45 pm
I do not believe this is possible.
You can use a filter to modify a dynamic route but it can't be copied.
If this can be done without making static routes I would like to know how as well.
megalogplus
Tue Jun 04, 2019 4:30 pm
Hello.
I faced the same task.
A lot of time has passed since the creation of this topic.
Maybe copying routes is already possible?
For example, in Linux there is a program "bird". With it, you can copy routes from one table to another using filters.
And on the routerOS, I do not understand how to do this?
mrz
Tue Jun 04, 2019 4:59 pm
You can use VRFs to install to specific table and advertised from it.
megalogplus
Tue Jun 04, 2019 5:02 pm
I read your wiki, but did not understand anything.
Can a simple example?
Railander
Wed Jul 24, 2019 10:42 pm
i've required this feature several times already.
i understand i could use a route reflector to give all my routes back to me and put then with a different routing mark, but that would require a separate router with extra physical connections, which makes no sense as it should be very easy to do a copy/paste locally yet it doesn't seem to be possible for some reason.
all i need is to get what dynamic routes (BGP, OSPF) i already have in my main routing mark and copy some of them to a different routing mark, while obviously still keeping them in the main table.
SimplyLiz
Mon Jul 29, 2019 2:31 am
cant this be done via VRF?
Users browsing this forum: No registered users and 31 guests
