MUM Europe 2020
mistiq
Problem with OSPF injecting to internal area.
Wed Apr 25, 2012 6:54 am
I have a next scheme - See attached picture:
In scheme i have 2 OSPF Area which connected over IPIP Tunnel And OSFP Backbone.
Each Mikrotik router have own ISP connection.
RA-RB and RA1-RB1 is Mikrotik RB1100AHx2 (ROS 5.14)
RC - cisco 4948 cat4500-entservicesk9-mz.122-50.SG1.bin
RC1 - cisco 3550 c3550-ipservicesk9-mz.122-44.SE6.bin
OSPF configuration:
RA:
 > routing ospf area print detail
Flags: X - disabled, I - invalid, * - default
 0  * name="backbone" instance=default type=default area-id=0.0.0.0
 1    name="VL" instance=VL type=default area-id=10.0.1.0
> routing ospf interface print detail
Flags: X - disabled, I - inactive, D - dynamic, P - passive
 0    interface=vlan_66_mgm cost=10 priority=255 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s
      hello-interval=5s dead-interval=10s use-bfd=no
 2    interface=ether2 cost=10 priority=255 authentication=none authentication-key="" authentication-key-id=1 network-type=broadcast instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=5s
      dead-interval=10s use-bfd=yes
 5    interface=ipip_vladlink_msk00_mastertel cost=40 priority=255 authentication=md5 authentication-key="109" authentication-key-id=1 network-type=point-to-point instance-id=0 retransmit-interval=5s
      transmit-delay=1s hello-interval=5s dead-interval=10s use-bfd=no
> routing ospf instance print detail
Flags: X - disabled, * - default
 0  * name="default" router-id=255.255.255.1 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=as-type-2 metric-default=1
      metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in out-filter=DNS-OUT
 1    name="VL" router-id=200.0.3.1 distribute-default=if-installed-as-type-1 redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=as-type-1
      metric-default=2 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter="" out-filter=""
> routing ospf network print detail
 0   network=172.20.3.96/30 area=VL (Transit MT-Cisco vlan_66)
 2   network=172.20.3.104/30 area=VL (Transit MT-MT ether2)
 5   ;;; Backbone Network MSK
     network=172.23.0.0/30 area=backbone
> routing filter print detail
Flags: X - disabled
 0   chain=DNS-OUT prefix=10.0.0.0/19 invert-match=no action=accept set-bgp-prepend-path=""
 1   chain=DNS-OUT prefix=172.20.0.0/19 invert-match=no action=accept set-bgp-prepend-path=""
 2   chain=DNS-OUT invert-match=no action=discard set-bgp-prepend-path=""
Another Mikrotik routers have same mirrored configurations (excluded OSPF RID AID etc)!!
Cisco 4948:
interface Vlan66
 description # MGM 1 VLAN #
 ip address 172.20.3.98 255.255.255.252
 ip ospf cost 10
 ip ospf hello-interval 5
 ip ospf dead-interval 10
 ip ospf priority 50
interface Vlan67
 description # MGM 2 VLAN #
 ip address 172.20.3.102 255.255.255.252
 ip ospf cost 10
 ip ospf priority 50
router ospf 100
 router-id 172.20.3.98
 log-adjacency-changes
 redistribute connected subnets
 redistribute static subnets
 network 172.20.3.96 0.0.0.3 area 10.0.1.0
 network 172.20.3.100 0.0.0.3 area 10.0.1.0
ip route 10.0.0.0 255.255.224.0 Null0 254
ip route 172.20.0.0 255.255.224.0 Null0 254
So when i bring up both of tunnel, i see very strange routing tables on mikrotik routers. For examle:
On RA:
> ip route print detail
29 ADo  dst-address=10.3.0.0/19 gateway=172.23.0.2 gateway-status=172.23.0.2 reachable via  ipip_vladlink_msk00_mastertel distance=110 scope=20 target-scope=10 ospf-metric=50 ospf-type=external-type-1
88 ADo  dst-address=172.23.0.0/19 gateway=172.23.0.2 gateway-status=172.23.0.2 reachable via  ipip_vladlink_msk00_mastertel distance=110 scope=20 target-scope=10 ospf-metric=50 ospf-type=external-type-1
> routing ospf print detail
27 instance=VL dst-address=10.3.0.0/19 state=imported-ext-1 gateway="" interface="" cost=50 area=external
82 instance=VL dst-address=172.23.0.0/19 state=imported-ext-1 gateway="" interface="" cost=50 area=external
94 instance=default dst-address=10.3.0.0/19 state=ext-1 gateway=172.23.0.2 interface=ipip_vladlink_msk00_mastertel cost=50 area=external
98 instance=default dst-address=172.23.0.0/19 state=ext-1 gateway=172.23.0.2 interface=ipip_vladlink_msk00_mastertel cost=50 area=external
99 instance=default dst-address=172.23.0.0/30 state=intra-area gateway=0.0.0.0 interface=ipip_vladlink_msk00_mastertel cost=40 area=backbone
Possible it is correct FIB
On RB:
29 ADo  dst-address=10.3.0.0/19 gateway=172.20.3.105 gateway-status=172.20.3.105 reachable via  ether2 distance=110 scope=20 target-scope=10 ospf-metric=60 ospf-type=external-type-1
30  Do  dst-address=10.3.0.0/19 gateway=172.23.0.6 gateway-status=172.23.0.6 reachable via  ipip_vladlink_temp_msk00_centertel distance=110 scope=20 target-scope=10 ospf-metric=20 ospf-type=external-type-1
89 ADo  dst-address=172.23.0.0/19 gateway=172.23.0.6 gateway-status=172.23.0.6 reachable via  ipip_vladlink_temp_msk00_centertel distance=110 scope=20 target-scope=10 ospf-metric=20 ospf-type=external-type-1
34 instance=VL dst-address=10.3.0.0/19 state=ext-1 gateway=172.20.3.105 interface=ether2 cost=60 area=external
89 instance=VL dst-address=172.23.0.0/19 state=imported-ext-1 gateway="" interface="" cost=20 area=external
1 instance=default dst-address=10.3.0.0/19 state=ext-1 gateway=172.23.0.6 interface=ipip_vladlink_temp_msk00_centertel cost=20 area=external
5 instance=default dst-address=172.23.0.0/19 state=ext-1 gateway=172.23.0.6 interface=ipip_vladlink_temp_msk00_centertel cost=20 area=external
1) RB takes two route to 10.3.0.0/19 from other sources (Over TunB and contiguous ether2 interface). First route have metric 60 (ospf cost 60), second - metric 20 (ospf cost 60).
But both of routes are installed to FIB (!!!) and RB send packet to 10.3.0.0/19 over ether2. I think it is not correct behavior.
2)Route to 172.23.0.0/19 have cost=20 in instance=VL and i can not see this route received from backbone.
I try inject external route to internal area with option "other ospf metric = 40" from RA and "other ospf metric = 10" from RB and get same results.
K.i.s.S.
Users browsing this forum: No registered users and 11 guests
