simpl3x
igmp, pim, multicast routing
Thu Apr 26, 2012 1:15 pm
There are two abstract network. one is the source of IPTV.
is a problem: multicast routing from one network to another.
At the IPTV server default gateway 192.168.10.1
238.1.1.0/24 - multicast addresses
Router A
[admin@MikroTik] /routing pim> interface print
Flags: X - disabled, I - inactive, D - dynamic, R - designated-router,
v1 - IGMPv1, v2 - IGMPv2, v3 - IGMPv3
 #      INTERFACE                            PROTOCOLS
 0   v2 all                                  pim
                                             igmp
 1 D v2 vlan100                              pim
                                             igmp
 2 D v2 ether2                               pim
                                             igmp
 2 DR   ether2                               pim
 3 DR   register                             pim
[admin@MikroTik] /routing pim> rp print detail
Flags: D - dynamic, X - disabled
 0    address=B.B.B.B type=static group=238.1.1.0/24 priority=192
      hash-mask-length=30 active-groups=0
[admin@MikroTik] /routing pim> join print
Flags: RP - (*,*,RP), WC - (*,G), SG - (S,G), SG_rpt - (S,G,rpt)
       GROUP           SOURCE          RP
    WC 224.0.0.0       B.B.B.B   B.B.B.B
    WC 224.0.0.0       192.168.123.1   192.168.123.1
    SG 238.1.1.1       0.0.0.0         B.B.B.B
    SG 239.255.255.250 0.0.0.0
Router B
[admin@routerB] /routing pim> interface print
 0   v2 all                                  pim
                                             igmp
 1 DRv2 v200                                 pim
                                             igmp
 2 DRv2 v207                                 pim
                                             igmp
 3 DRv2 v209                                 pim
                                             igmp
 4 DRv2 v204                                 pim
                                             igmp
 5 DRv2 v206                                 pim
                                             igmp
 6 DRv2 v205
 7 DRv2 v20
 8 DRv2 ether3_inet
 9 DRv2 ether2_wlocal
10 DRv2 ether1_local                         pim
                                             igmp
11 DRv2 v202                                 pim
                                             igmp
12 DRv2 v203                                 pim
                                             igmp
13 DRv2 VIDEO_1PKT                           pim
                                             igmp
14 DR   register                             pim
[admin@routerB] /routing pim> rp print detail
 0    address=192.168.10.2 type=static group=238.1.1.0/24 priority=192 hash-mask-length=30 active-groups=0
[admin@routerB] /routing pim> join print
       GROUP           SOURCE          RP
SG_rpt 238.1.1.1       192.168.10.2    192.168.10.2
SG_rpt 238.1.1.2       192.168.10.2    192.168.10.2
SG_rpt 238.1.1.3       192.168.10.2    192.168.10.2
SG_rpt 238.1.1.4       192.168.10.2    192.168.10.2
SG_rpt 238.1.1.5       192.168.10.2    192.168.10.2
The client does not see IPTV. what's wrong? what else would you show?
With best regards, from Russia =)
simpl3x
Re: igmp, pim, multicast routing
Thu Apr 26, 2012 4:07 pm
All remove and recreate by the description: http://wiki.mikrotik.com/wiki/Manual:Mu ... ed_example
Router A
ether1 to User
ether2 to Router B
Flags: X - disabled, I - inactive, D - dynamic, R - designated-router, v1 - IGMPv1, v2 - IGMPv2, v3 - IGMPv3
 0  Rv2 ether1        pim
        igmp
 1  Rv2 ether2        pim
        igmp
 2 DR   register        pim
 #    ADDRESS         TYPE        PRIORITY
 0    B.B.B.B  static           192
       GROUP           SOURCE          RP
    SG 238.1.1.3       0.0.0.0         B.B.B.B
    SG 239.255.255.250 0.0.0.0         B.B.B.B
SG_rpt 239.255.255.250 B.B.B.B   B.B.B.B
SG_rpt 239.255.255.250 192.168.123.254 B.B.B.B
[admin@MikroTik] > ip route print where dst-address=224.0.0.0/4
 0 A S  224.0.0.0/4                        B.B.B.B             1
 1  Do  224.0.0.0/4                        B.B.B.B           110
LOG:
00:57:09 pim,warning JoinDesired(*,G) = true: upstream neighbor for RP B.B.B.B for group 238.1.1.3: not found
Router B
VIDEO_1PKT to Multicast sender
ether3_inet to Router A
[admin@routerB] > routing pim interface print
 0   v2 all        pim
        igmp
 1 D v2 v200        pim
        igmp
 2 DRv2 v202        pim
        igmp
 3 DRv2 v207        pim
        igmp
 4 DRv2 v209        pim
        igmp
 5 DRv2 v204        pim
        igmp
 6 DRv2 v205        pim
        igmp
 7 DRv2 v206        pim
        igmp
 8 DRv2 v20        pim
        igmp
 9 DRv2 ether2_wlocal        pim
        igmp
10 DRv2 ether3_inet        pim
        igmp
11 DRv2 ether1_local        pim
        igmp
12 DRv2 v203        pim
        igmp
        igmp
13 DR   VIDEO_1PKT        pim
14 DR   register        pim
[admin@routerB] > routing pim rp print
[admin@routerB] > routing pim join print where source=192.168.10.2
       GROUP           SOURCE          RP
    WC 224.0.0.0       192.168.10.2    192.168.10.2
any suggestion?
mehanik
Thu Apr 26, 2012 6:23 pm
help to realize iptv viewing from both providers at the same time
simpl3x
Wed May 02, 2012 10:33 am
please help!
Cronex
Sun Feb 02, 2014 10:03 am
please help!
Join to question
RB2011UAS-RM, CCR1016-12G
Cronex
Wed Mar 23, 2016 5:34 am
Up for help to realize iptv viewing from both providers at the same time
ZeroByte
Mon Apr 04, 2016 9:24 pm
I'm definitely not an expert with multicast, but offhand, I would say that you need to configure the RP address for ISP1's group to be ISP1's RP, and a different RP for ISP2's group.
If they just want IGMP from your device then you may just need to use IGMP proxy (no PIM), and set the group and upstream interfaces as static entries in the MFC tab.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Users browsing this forum: No registered users and 25 guests
