Ivoshiee
OSPF NBMA-neighbour cost?
Sun Jun 24, 2012 5:12 pm
I am just getting to know some OSPF and its trickery, but I wonder if the NBMA-neighbour is basically the same as the usual OSPF interface then how does one set the NBMA-neighbour cost? Or is it indirectly calculated from some other parameter?
samsung172
Re: OSPF NBMA-neighbour cost?
Sun Jun 24, 2012 10:46 pm
Its just to set cost, at the interface. It does not matter if its nbma ore something oher. Only difference is to set priority at nbma neighbor (and most likely put the same cost at other sides interface)
Ivoshiee
Mon Jun 25, 2012 3:49 pm
Thanks.
MikroTikIQ
Trainer
Trainer
Tue Jun 26, 2012 10:39 pm
NBMA... its mean you can built your OSPF Network manully like you can specify which router will the Designated and which router will be Back designated..
There is more detail about you can find in the WiKi too...
Best regards
Ali.
Users browsing this forum: No registered users and 32 guests
