MUM Europe 2020
kellogs
enabled ibgp between 2 Mikrotik crashed 5.20
Sun Sep 30, 2012 11:05 am
Router1:
ISP1
ISP2
ISP3 (local internet exchange)
Router2:
ISP4
ISP5
I have established sesson between these two routers 1 and 2 so that Router 2 is able to learn the route from Router1 for ISP3 (local Internet change) but it crashed the Mikrotik where both units became unresponsive. To fix this problem I had to disable the ibgp session between these 2 routers.
our AS is 1234
Router1 iBGP config
name="ibgp-office" instance=default remote-address=172.31.1.1 remote-as=1234>
tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no
hold-time=3m ttl=default in-filter="" out-filter="" address-families=ip
default-originate=never remove-private-as=no as-override=no passive=no
use-bfd=no
Router 2 iBGP config
name="ibgp-dc" instance=default remote-address=172.31.1.2 remote-as=1234
use-bfd=no
Anyone kindly to share some tips?
Thank you! ;)
rodolfo
Long time Member
Long time Member
Re: enabled ibgp between 2 Mikrotik crashed 5.20
Sun Sep 30, 2012 11:38 am
how many routes are exchanged ?
the channel used to Exchange routes is the same you use to access these routers ?
which routers do you use ?
how many ram the routers have ?
rodolfo
IZ0UQV
kellogs
Sun Sep 30, 2012 12:42 pm
the routes from ISP3 is 8129
But I think routes from ISP1, ISP2, ISP4 and ISP5 would be exchanged on this link as well.
Each ISP we are receiving full routing table about 420K prefixes.
The channel which I am using to setup this iBGP is a dedicated interface.
Each router has 2GB Memory and each of them after BGP peering with their respective peers are 1.4GB free.
rodolfo
Long time Member
Long time Member
Sun Sep 30, 2012 5:37 pm
sorry, I ask the model of your mikrotik router.
do you use an RB1000 or an RB1100Ax2 ?
when this routers load a bgp full table, the cpu goes to 100% for a while.
do not use winbox during the initialization.
never open ip routes.
rodolfo
IZ0UQV
kellogs
Sun Sep 30, 2012 6:34 pm
Hi Rodolfo,
We are using x86 Mikrotik with 8 Cores CPU.
The CPU Load is very little during the peering.
Is it a known bug that it would caused such problem?
rodolfo
Long time Member
Long time Member
Mon Oct 01, 2012 10:09 pm
no, with your hardware you must not have problems!
be shure to acetive multi-cpu=yes
send supout.rif to the support
rodolfo
IZ0UQV
kellogs
Tue Oct 02, 2012 8:36 am
Hi rodolfo,
Do you think if it is better for me to setup a filter in and out for the iBGP peer?
rodolfo
Long time Member
Long time Member
Tue Oct 02, 2012 6:22 pm
an in filter and out filter it is always advisable
rodolfo
IZ0UQV
Users browsing this forum: No registered users and 12 guests
