MUM Europe 2020
Nemoo
Problem with routing protocol RIPng.
Fri Oct 19, 2012 6:21 pm
Problem with routing protocol RIPng after shutdown another router.
				AP
				|---Host1
R3-------R2-(eth5,eth3,eth2)------------R1(gateway)
		 |(Vlan5,Vlan6 on eth4)
		 Host2
[admin@R2] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME                                    MTU MAC-ADDRESS       ARP        MASTER-PORT                                 SWITCH
 0    ether1-inna                            1500 XX:XX:XX:XX:XX:XX enabled    none                                        switch1
 1 R  ;;; Komp1
      ether2-local-master                    1500 XX:XX:XX:XX:XX:XX enabled    none                                        switch1
 2  S ;;; AP
      ether3-local-slave                     1500 XX:XX:XX:XX:XX:XX enabled    ether2-local-master                         switch1
 3 R  ;;; Terminal
      ether4-local-slave                     1500 XX:XX:XX:XX:XX:XX enabled    none                                        switch1
 4 RS ;;; Net
      ether5-local-slave                     1500 XX:XX:XX:XX:XX:XX enabled    ether2-local-master                         switch1
[admin@R2] > /interface vlan print
 #    NAME                                                             MTU ARP        VLAN-ID INTERFACE
 0 R  vlan_5                                                          1500 proxy-arp        5 ether4-local-slave
 1 R  vlan_6                                                          1500 enabled          6 ether4-local-slave
[admin@R2] > /ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-... INTERFACE        ADV
 0  G 2001:xxx:aaa:3::1/64                                vlan_5           no
 1  G 2001:xxx:bbb:35::2/64                                 bridge1          no
 2  G 2001:xxx:aaa:4::1/64                                vlan_6           no
[admin@R2] > /routing ripng interface print
Flags: I - invalid, X - disabled, P - passive
 0    interface=all in-prefix-list="" out-prefix-list=""
 [admin@R2] > /routing ripng print
      distribute-default: never
     redistribute-static: no
  redistribute-connected: yes
       redistribute-ospf: no
        redistribute-bgp: no
          metric-default: 1
           metric-static: 1
        metric-connected: 1
             metric-ospf: 1
              metric-bgp: 1
            update-timer: 30s
           timeout-timer: 3m
           garbage-timer: 2m
R2 in the routing table does not address types connect, but all rip. ????
[admin@R2] > /routing ripng route print
Flags: C - connect, S - static, R - rip, O - ospf, B - bgp
 #   DST-ADDRESS                                 GATEWAY                                     METRIC TIMEOUT
 0 R 2000::/3        2 2m51s
 1 R 2001:xxx:ccc:35::/64        2 2m51s
 2 R 2001:xxx:bbb:35::/64        1
 3 R 2001:xxx:aaa:2::/64        2 2m51s
 4 R 2001:xxx:aaa:3::/64        1
 5 R 2001:xxx:aaa:4::/64        1
I shutdown router R3.
I look route on R2 and see(metric 16 on connected networks):
 0 R 2000::/3        2 2m32s
 1 R 2001:xxx:ccc:35::/64        2 2m32s
 2 C 2001:xxx:bbb:35::/64        16 1m32s
 3 R 2001:xxx:aaa:2::/64        2 2m18s
 4 C 2001:xxx:aaa:3::/64        16 1m32s
 5 C 2001:xxx:aaa:4::/64        16 1m32s
[admin@R2] > ping 2001:xxx:aaa:3::15
HOST                                     SIZE TTL TIME  STATUS
2001:xxx:aaa:3::15                        56  64 8ms   echo reply
    sent=1 received=1 packet-loss=0% min-rtt=8ms avg-rtt=8ms max-rtt=8ms
 0 R 2000::/3        2 2m57s
 1 R 2001:xxx:ccc:35::/64        2 2m57s
Where is now redistribute connected networks?
I can rerun:
[admin@R2] > /routing ripng interface disable 0
[admin@R2] > /routing ripng interface enable 0
 3 R 2001:xxx:aaa:3::/64        1
 4 R 2001:xxx:aaa:4::/64        1
Nemoo
Re: Problem with routing protocol RIPng.
Fri Nov 23, 2012 10:06 am
Does anyone have the same problem with the RIPng?
So instead of connections, type "connect" are seen by the router "R2" as RIPng.
After turning off the router "R3" router "R2" loses network routing table, which wrong seen as "RIPng" but should it be a network "connect".
After reboot, RIPng protocol. Networks are visible again.
My question is as follows:
Do I have something misconfigured?
Are you perhaps a bug that should be reported to Support MT?
Users browsing this forum: No registered users and 8 guests
