mtik
Problem in forwarding port80 when mangle rule is enabled
Thu Nov 15, 2012 5:20 pm
hi,
newbie here, needing your help.
my port80 forwarding(hair pin code) does not function when mangle rule load balancing(urdu guide) is enable.
thanks in advance for your prompt attention.
NAB
Trainer
Trainer
Re: Problem in forwarding port80 when mangle rule is enabled
Fri Nov 16, 2012 11:49 am
You forgot to attach your code. I don't think anybody here is psychic, so you're probably not going to get any help unless you can post details of your configuration!
Users browsing this forum: No registered users and 13 guests
