sirkike
Public IP's
Fri Feb 15, 2013 2:58 am
Hi, i need to set a router to manage a /24 publics ip address, but in the clients don't work... help.
From my ISP...
Network: AA.BB.CC.100/30
Gateway: AA.BB.CC.101
Public IP Pool: DD.EE.FF.0/24
In my Mikrotik...
[admin@gate] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   AA.BB.CC.102/30   AA.BB.CC.100   ether1
 1   DD.EE.FF.1/24     DD.EE.FF.0     ether2
[admin@gate] >
[admin@gate] > ip route print
 0   S  0.0.0.0/0                          AA.BB.CC.101              1
 1 ADC  AA.BB.CC.100/30    AA.BB.CC.102    ether1                    0
 2 ADC  DD.EE.FF.0/24      DD.EE.FF.1      ether2                    0
[admin@gate] >
[admin@gate] > ip firewall nat print
 0   chain=srcnat action=masquerade src-address=DD.EE.FF.0/24 out-interface=ether1
[admin@gate] >
And, in the client configure:
IP: DD.EE.FF.2
Mask: 255.255.255.0
Gateway: DD.EE.FF.1
DNS: 8.8.8.8, 8.8.4.4
but i can't go outside, ping don't respond... ping google.com and timeout...
manson
Re: Public IP's
Fri Feb 15, 2013 9:45 am
And what about connection tracking? You have to set it to enable.
[admin@Domek] > ip firewall connection tracking print
                   enabled: yes
      tcp-syn-sent-timeout: 5s
  tcp-syn-received-timeout: 5s
   tcp-established-timeout: 1h
      tcp-fin-wait-timeout: 10s
    tcp-close-wait-timeout: 10s
      tcp-last-ack-timeout: 10s
     tcp-time-wait-timeout: 10s
         tcp-close-timeout: 10s
               udp-timeout: 10s
        udp-stream-timeout: 3m
              icmp-timeout: 10s
           generic-timeout: 10m
             tcp-syncookie: no
               max-entries: 481448
             total-entries: 26
CelticComms
Re: Public IP's
Fri Feb 15, 2013 2:54 pm
Can you ping the ISP gateway? Which DNS servers are you using - are lookups working?
Do you have any NAT rules active?
Output from /export compact would be useful.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
SwissWISP
Re: Public IP's
Fri Feb 15, 2013 3:04 pm
Hi!
Since you are routing a public IP-Range, you don't need "masquerade".
Everything else looks good.
First thing you should check is, if your RB is able to ping your GW, which is AA.BB.CC.101 in your example. If this isn't possible your problem lies between your RB and your ISP.
If you've got networking problems, please try to ping IP addresses instead of domain names.
- Mat
cupis
Re: Public IP's
Fri Feb 15, 2013 7:47 pm
Maybe your ISP has not got that /24 setup to route to your router, so return traffic is not making it to you...
sirkike
Re: Public IP's
Sat Feb 16, 2013 1:14 am
Thanks, was the nat rule :/ jeje. This is the best way to routing public ip range?
SwissWISP
Re: Public IP's
Sat Feb 16, 2013 11:57 am
Well, it's the correct way of routing... What would you change?
Users browsing this forum: No registered users and 15 guests
