buddyfox
Propagate routes for customers BGP peer
Thu Mar 28, 2013 8:19 pm
Gentlemen, I am a layman in the subject.
I am a provider and a client will connect via BGP with our router.
Have climbed the session but on his side he only receives prefix-count = 1.
How could we get our table full and send to peer client?
sorry for my english
lambert
Long time Member
Long time Member
Re: Propagate routes for customers BGP peer
Fri Mar 29, 2013 12:38 am
Do you speak eBGP to your providers?
Do you get full tables from your providers, or just default routes (0.0.0.0/0)?
Does the router which speaks eBGP to your customer also speak iBGP to your router which speaks eBGP to your provider?
On the router which speaks to the customer, try:
/ip route print where bgp
Does that return 1 route? Some routes? Or more that 100,000 routes?
Do the same on the router which speaks to your providers, if that router is Mikrotik.
buddyfox
Fri Mar 29, 2013 2:42 am
Yes, eBGP, full tables.
Let's use the same router that does eBGP who is receiving full routing to establish another eBGP to our customer
We're getting more than 500k routes.
I want to propagate the same routing table of the main router to the client.
MikroTikIQ
Trainer
Trainer
Fri Mar 29, 2013 9:23 pm
Hi..
Could you please draw topology of your connectivity and also send me the export of routing configuration
/ routing bgp export
This way I can undrestand how to figure out your problem and fix it..
Best regards
Ali Sami
_________________
MikroTik Authorize trainer
MTCNA-MTCTCE-MTCWE-MTCRE-MTCINE
Users browsing this forum: No registered users and 8 guests
