beepee
Route OSPF error: Discarding packets
Wed Apr 03, 2013 6:44 pm
Hi guys
Please I have been seeing this error message on some of my routers:
Route OSPF error: Discarding packets: locally originated src-address=10.x.x.x (one of the routers IP address)
Please what could be the cause of the problem.
mrz
Re: Route OSPF error: Discarding packets
Thu Apr 04, 2013 10:12 am
If you are running v5 and have simple queues this error may appear. It is fixed in v6.
beepee
Thu Apr 04, 2013 1:08 pm
Thanks mrz
It is true that my routers are on v5.2x but I don't have queues in place on any of the routers.
The only router that has simple queues is not running ospf, its on static routing and as such its not giving that error.
I will try V6 and see if that will resolve the problem.
mrz
Thu Apr 04, 2013 1:14 pm
Then you have a routing loop, or you have multiple interfaces connected to the same routers and on all of them OSPF is set up.
bysard
Tue Apr 30, 2013 6:05 pm
I see the same problem for a month now and didn't see it before 5.18. No topology has changed.
mistiq
Wed May 01, 2013 4:27 am
+1
I can see this error on 5.24.
My topology prevent routing loops at all.
K.i.s.S.
beepee
Wed May 01, 2013 6:52 pm
+1
My topology is basically star and has grown to a tree-like structure.
I mean some routers in the star stucrure now has some routers connected to them.
The routes are quite clear and I see no reason why I should have loops.
I have upgraded to V6 but yet, the problem still persist.
atwind
Fri May 24, 2013 1:40 pm
i have the same problem too..
help please.. :(
bysard
Thu May 30, 2013 8:50 am
Anything new on this? 8 lines of ospf errors per 3 seconds in log. Nothing changed no new routers or rules added.
maxstel
Trainer
Trainer
Fri May 31, 2013 7:49 pm
On another topic, I don't remember where, I read that this problem could be related to designated router decisions...
I've changed priority on routers with this error some days ago and errors disappeared...
RouterOS 5.x (some 5.22, 5.24 and 5.25)
Massimo Passerini
STEL S.r.l.
Ferrara - Italy
MikroTik Certified Trainer
bysard
Sat Jun 01, 2013 10:27 pm
I can confirm this. Also got confirmation from Mikrotik support. It's a bug and it will be fixed in future version, but they did not say if it's going to be fixed in RoS 5.
davidnvega
Thu Nov 07, 2019 2:30 pm
Is this an error?? To a have two routers connected with two differents interface for backup??
Sorry for my English, I speak Spanish.
Users browsing this forum: blackmetal and 17 guests
