MUM Europe 2020
mistiq
OSPF if-installed doesn`t work
Wed Jun 05, 2013 9:59 am
I have Mikrotik and Cisco with next network diagram:
dst-address=0.0.0.0/0 gateway=188.246.xxx.x gateway-status=188.246.xxx.x reachable via  wan_avers check-gateway=ping distance=1 scope=30 target-scope=10
#show ip route vrf LOCAL
Routing Table: LOCAL
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.20.96.109 to network 0.0.0.0
     172.20.0.0/30 is subnetted, 3 subnets
C       172.20.96.204 is directly connected, Vlan900
C       172.20.96.112 is directly connected, Vlan69
C       172.20.96.108 is directly connected, Vlan68
O*E2 0.0.0.0/0 [110/1] via 172.20.96.109, 00:00:38, Vlan68
(МТ1) (This is VRF vlan)
Mikrotik 1 redistributed default route to cisco with "Redistribute Default Route = If installed (as type 1)" option and metric=1 into cisco VRF.
Mikrotik 2 redistributed default route to cisco with "Redistribute Default Route = If installed (as type 1)" option and metric=2 into cisco VRF.
When default route on MT1 become "unreachable":
dst-address=0.0.0.0/0 gateway=188.246.xxx.x gateway-status=188.246.xxx.x unreachable check-gateway=ping distance=1 scope=30 target-scope=10
For few second default route on cisco become :
O*E1 0.0.0.0/0 [110/12] via 172.20.96.113, 00:00:02, Vlan69
(МТ2)
And back to
O*E1 0.0.0.0/0 [110/11] via 172.20.96.109, 04:05:55, Vlan68
On MT1 i can see
2 ADo  dst-address=0.0.0.0/0 gateway=172.20.96.98 gateway-status=172.20.96.98 reachable via  vlan_66_mgm distance=110 scope=20 target-scope=10 ospf-metric=22 ospf-type=external-type-1
(This is main table on cisco)
What i do wrong? Why MT1 redistrubute route received from other MT?
K.i.s.S.
mrz
Re: OSPF if-installed doesn`t work
Wed Jun 05, 2013 10:59 am
Which version you are running? v6.0 should have fixed default route distribution in this setup.
mistiq
Wed Jun 05, 2013 11:24 am
we are running exactly 6.0
K.i.s.S.
mrz
Wed Jun 05, 2013 12:01 pm
Send supout files from all three routers to support.
okoun
Fri Jun 07, 2013 1:15 am
I have exactly the same problem, it looks like the global version 6 error
mistiq
Sat Jun 08, 2013 6:37 am
Support says it`s normal that mikrotik re-redistribute received ospf routes when if-installed option are enabled :(
I think it`s stupid.
K.i.s.S.
Users browsing this forum: CZFan and 9 guests
