Equis
Forum Veteran
Forum Veteran
Nat stopping OSPF working
Fri Jul 26, 2013 6:42 am
Hello
my whole network uses OSPF, runs really well all OK except one router in our office.
It won't fill the routing table on reboot.
I found out if I disable NAT on the router it will then work fine.
I can enable NAT after a min and it will stay working fine till next reboot.
Any Idea's on this?
Rhys
CelticComms
Re: Nat stopping OSPF working
Tue Jul 30, 2013 7:29 am
Can you upload the config from the affected system? Also try enabling OSPF debug and see what the log shows during the problem phase.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
Users browsing this forum: No registered users and 13 guests
