Connecting ATT u-verse through a NVG510 Bridge Mode (dynamic)
I set up a RB493 with ROS 5.1.
I put a DHCP client on ether1 and received an address with /32
162.1xx.xx1.115/32
and a gateway in an adjacent /24
162.1xx.xx0.1
The route 0.0.0.0/0 showed up blue in the routes scree
Needless to say I got no connection
As a HACK I added the same address as a static with a larger netmask
162.1xx.xx1.115/23
Boom, net is up.
But this is not a permanent solution because the address is assigned DHCP.
FYI
I tried routing 0.0.0.0/0 to the interface ether1 first but that did not work.
Plugging in a windows laptop gets the same address mask and gateway, but works arg!
ANY IDEAS
