MUM Europe 2020
ropeba
CCR - Multicast over EoIP, and PPPoE problem
Thu Jan 09, 2014 12:52 pm
Hi, I have the following problem with CCR. So, I have EoIP tunnel that only passes through the CCR (he's not terminate to the CCR).
RB2011 (1)> CCR> RB2011 (2)
EoIP is terminated on the RB2011 (1) and RB2011 (2) and through it passes multicast (IPTV), not much, 5-6 mbps - one TV channel.
Happens to me that, when someone connects with PPPoE or disconnects the CCR, the image on the IPTV stream stops briefly, half a second, or pixelisation appears and tone is paused briefly. Can you please check what's the problem and why this is happening because the CCR is not doing anything about terminating EoIP, just passing through him. ROS is 6.1 version.
janisk
Re: CCR - Multicast over EoIP, and PPPoE problem
Fri Jan 10, 2014 3:32 pm
please try on the latest release of RouterOS if behaviour is the same.
ropeba
Fri Jan 10, 2014 8:28 pm
Last edition of ROS has too many bugs and it' unstable and it' s on CORE router and I don't dare to do an upgrade. On routers on which I tested 6.7 I had problems, users are faced with Internet breaks, IPs and DHCP server are gone, half of RB services is not in function etc.
ropeba
Thu May 15, 2014 11:23 am
This problem still persist, in version 6.12.
mobilexpi
Sun Sep 04, 2016 7:27 am
@ropeba
Did you find any solution for this? I'm having the same issue.
Users browsing this forum: No registered users and 6 guests
