drvirus
multicasting between mikrotik and cisco over gre tunnel
Sun Apr 20, 2014 4:56 pm
hi all ,
im trying to setup multicast between mikrotik and cisco router
the topology as below :
<multicast reciver>--------eth2--mikrotik--eth1-----internet---------Cisco Router----<multicast transmitter>
here is more details here
the transmitter and reciver can ping them by thier unicast addresses , i have made a routing for two lan subnets between cisco and mikrotik
but there is no multicast @ the reciver in the mikrotik side !!!
now on cisco , i setup it and i tested it with another cisco router and it was success .
but
recently i replaced the cisco router with mikrotik router , but i cant receive multicast
i dont know why ?!!!
i disabled firewall but no luck
i will paste config of mikrotik
[admin@MikroTik] > /export
# jan/04/2002 02:24:15 by RouterOS 5.26
# software id = M9PP-XUBH
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:35:89:6F master-port=\
none mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:35:89:70 master-port=\
none mtu=1500 name=ether2-master-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:35:89:71 master-port=\
ether2-master-local mtu=1500 name=ether3-slave-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:35:89:72 master-port=\
ether2-master-local mtu=1500 name=ether4-slave-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
yes full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:35:89:73 master-port=\
ether2-master-local mtu=1500 name=ether5-slave-local speed=100Mbps
/interface gre
add disabled=no dscp=0 l2mtu=65535 local-address=x.x.240.6 mtu=1400 name=\
Ahmd remote-address=z.z.160.200
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1 switch-all-ports=yes
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add address-pool=default-dhcp authoritative=after-2sec-delay bootp-support=\
static disabled=yes interface=ether2-master-local lease-time=3d name=\
default
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=default \
use-encryption=default use-mpls=default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web\
,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass\
word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi\
nbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
set 5 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:20:45:1E:4C:98 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.17.0.1/24 comment="default configuration" disabled=no interface=\
ether2-master-local network=10.17.0.0
add address=x.x.240.6/30 disabled=no interface=ether1-gateway network=\
193.212.240.4
add address=172.16.21.2/24 disabled=no network=172.16.21.0
add address=172.16.40.2/24 disabled=no interface=Ahmd network=172.16.40.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
default-route-distance=1 disabled=no interface=ether1-gateway use-peer-dns=\
yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.88.0/24 comment="default configuration" dhcp-option="" \
dns-server=192.168.88.1 gateway=192.168.88.1 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=""
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether2-master-local disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-slave-local disabled=no
set Ahmd disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=x.x2.240.5 scope=30 \
target-scope=10
add disabled=no distance=1 dst-address=10.17.17.3/32 gateway=172.16.40.1 scope=\
30 target-scope=10
30 target-scope=10
add disabled=no distance=1 dst-address=10.17.17.27/32 gateway=172.16.40.1 \
scope=30 target-scope=10
add disabled=no distance=1 dst-address=10.17.17.147/32 gateway=172.16.40.1 \
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=no port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=yes inactive-flow-timeout=\
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=only-hardware-queue
set ether2-master-local queue=only-hardware-queue
set ether3-slave-local queue=only-hardware-queue
set ether4-slave-local queue=only-hardware-queue
set ether5-slave-local queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=yes
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing pim interface
add alternative-subnets="" assert-override-interval=3s assert-time=3m disabled=\
no dr-priority=1 hello-holdtime=1m45s hello-period=30s \
hello-trigerred-delay=5s igmp-version=IGMPv2 interface=Ahmd \
join-prune-holdtime=3m30s join-prune-period=1m override-interval=250 \
preferred-source-address=0.0.0.0 propagation-delay=50 protocols=pim,igmp \
require-hello=yes tracking-support=yes
hello-trigerred-delay=5s igmp-version=IGMPv2 interface=ether2-master-local \
hello-trigerred-delay=5s igmp-version=IGMPv2 interface=ether1-gateway \
hello-trigerred-delay=5s igmp-version=IGMPv2 interface=all \
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name=MikroTik
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=Ahmd store-on-disk=yes
/tool mac-server
set [ find default=yes ] disabled=yes interface=all
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol="" \
filter-mac-address="" filter-mac-protocol="" filter-port="" filter-stream=\
yes interface=all memory-limit=100KiB memory-scroll=yes only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
[admin@MikroTik] >
any help ??
im dying to fix this issue , and i wish to have a solution's this time
regards
rickfrey
Trainer
Trainer
Re: multicasting between mikrotik and cisco over gre tunnel
Mon Apr 21, 2014 5:16 pm
Will you also post your Cisco config?
Launch your company forward with professional training!
http://rickfreyconsulting.com/product-c ... raining-2/
drvirus
Mon Apr 21, 2014 5:49 pm
hi ,
sure i will
here is myconfig @ cisco :
cisco900#sh run
Building configuration...
Current configuration : 6810 bytes
version 15.1
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname cisco900
boot-start-marker
boot-end-marker
enable secret 4 Wiuhjknm
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
multilink bundle-name authenticated
license udi pid CISCO2901/K9 sn iugh2C5V8
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
redundancy
interface Tunnel5
 ip address 172.16.40.1 255.255.255.0
 ip mtu 1400
 ip pim dense-mode
 ip tcp adjust-mss 1360
 tunnel source GigabitEthernet0/0
 tunnel destination z.z.240.6 ===>public ip ofmikrotik
interface GigabitEthernet0/0
 ip address x.x.160.200 255.255.255.0 ===> public ip of cisco router
 ip pim dense-mode
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.17.17.3 255.255.255.0
 ip pim dense-mode
 ip nat inside
 duplex auto
 speed 100
interface Virtual-PPP3
 no ip address
i
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list INTERNET interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.17.17.27 3389 interface GigabitEthernet0/0 3389
ip nat inside source list NATPPTP interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 85.252.160.1
ip route 10.17.0.0 255.255.255.0 172.16.40.2
i
ip access-list extended INTERNET
 deny ip any 10.17.0.0 0.0.0.255
 permit ip 10.17.17.0 0.0.0.255 any
route-map dod
cisco900#
regards
w0lt
Long time Member
Long time Member
Mon Apr 21, 2014 7:18 pm
Do you have any Rendezvous Points established for you're multicast addresses?
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
w0lt
Long time Member
Long time Member
Mon Apr 21, 2014 7:21 pm
I also just noticed that you are running PIM-Dense mod on the Cisco. Not sure if will affect the tik box since they only support sparse mode... Maybe nothing..
Might think about establishing BSR/RP Candidates on the appropriate interfaces using the default Multicast range.
MTCNA - 2011
drvirus
Mon Apr 21, 2014 7:52 pm
hi , yes
on cisco pim ==>dense mode
does mikrotik dont support pim ?and only work with sprase dense mode ?==> i was think that mikrotik has pim also there ??!!!
agian , i dont have rp point , configured for cisco , i just enabled pim there i thought that both has pim dense mode and no need for rp point.
wt do i need righ now ?? setup sparse dense mode on cisco ?
just that ?
w0lt
Long time Member
Long time Member
Mon Apr 21, 2014 9:10 pm
MikroTik does support PIM, obviously... :-).. But only Sparse Mode, which is actually more efficient. I use PIM-Sparse mode on my Tik boxes to a device that only uses PIM-Dense Mode and it seems to work ok. I'm not sure, but I believe Rendezvous Points need to be defined, not just running PIM or at least for MikroTik. No sure about CISCO, but I would believe you would have to do something like that too.
MTCNA - 2011
drvirus
Mon Apr 21, 2014 11:51 pm
ok on cisco i will replace dense with sparse dense mode.
but agian ,
can u guide me how to elect the rp ? is it mandatory or optional?
i want the cisco router to be as rp.
is that election manual ?
also done form cisco or mikrotik ?
can u help me
w0lt
Long time Member
Long time Member
Tue Apr 22, 2014 3:16 am
Can't speak much about CISCO. I'm sure there are others here that might be able to.
I let PIM elect RP's that way it can be dynamic. Below are illustrations of my PIM windows. I use a bridge Loopback interface to run PIM on, and a EoIP interface to my other link. Then, I let PIM do the work using the BSR on the default Multicast address range.
Seems to work great so far, and its kinda neat to watch it work.
MTCNA - 2011
Users browsing this forum: Google Adsense [Bot] and 8 guests
