Sun Jul 13, 2014 7:29 am
At first please see the attachment. I am using "interface bridge settings set use-ip-firewall=yes" because of queue B/W control. I have a VPN in cisco router , But main problem is when I am try to connect VPN , it was failed due to firewall on. Please give me solution to use firewall on and VPN access
