Premier
Odd OSPF route selection
Tue Jul 15, 2014 12:52 am
Please see attached screenshot. This is of a router, say R2, which is sandwiched between 2 other MT routers , R1 & R3 directly connected to interfaces ether_1, and ether_6 on R2
ISP1 <- >R1< - > R2 < - >R3< - >ISP2.
Ospf is running across all 3 routers, R1, 2 & 3. BGP is running on R1 and R3 only.
What seems to be happening to R2 is that its preferred gateway is ether_6, which ip/routes correctly indicates. but traffic is almost symmetrical, which it should not be. It also seem to be receiving traffic from ether_1, which I have weighted higher to stop R2 from using this interface unless ether_6 goes down.
How would I go about diagnosing this problem?
jkarras
Re: Odd OSPF route selection
Tue Jul 15, 2014 6:15 am
You will need to know what type of traffic is coming in. Is it traffic to/from a directly connected route e.g. non ISP traffic?
CelticComms
Tue Jul 15, 2014 7:05 am
What does the routing table look like on R2 and exactly what did you "weight"?
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
Premier
Fri Jul 18, 2014 12:21 pm
Here is a snipet of the routing table in R2. its gateway is 10.12.130.1 which is exactly where I want it to go...
I changed the weights or costs in routing/ospf/interfaces.
Premier
Fri Jul 18, 2014 12:31 pm
Actually, now that I look at the routes again, everything seems to be destined for 10.12.129.1, which is R3. I do not want it to go out through this router, so I have increased the costs of the ospf interfaces on both R2 and R3 to stop this.
But yet at the top of the routes it says everything, 0.0.0.0/0 is destined for 10.12.130.1 which is R1
CelticComms
Fri Jul 18, 2014 2:40 pm
Check the settings for default route redistribution from both your WAN routers including the cost for the default route. From your screenshot the router attached to Ether 6 is offering a more attractive default route than the other router while the explicit routes offered by the router on Ether 1 are being favoured.
Premier
Sat Jul 19, 2014 12:01 am
On both WAN routers, Redistribute Default Route if installed (as type 1) is selected.
Default Route Metric is 1 on both routers.
Premier
Sat Jul 19, 2014 12:12 pm
On both my BGP routers, should I have any of the Redistributes ticked under BGP/INSTANCES?
I had Redistribute Ospf ticked, but I removed it and now none of the redistributes are ticked, but the internet is still working.
Users browsing this forum: No registered users and 7 guests
