kellogs
migrating cisco to mikrotik
Fri Aug 01, 2014 1:39 pm
Dear Member
I have the following config on Cisco
interface FastEthernet0/0
ip address 2.1.1.1 255.255.255.252
interface FastEthernet0/1
ip address 1.1.1.1 255.255.255.252
interface Vlan1
description -=LAN-1=-
ip address 192.168.1.1 255.255.255.0
Interface 0/0 and 0/1 IPs are for BGP with 2 upstream and Vlan1 is the LAN IP. I have assigned those 3 IPs onto mikrotik individual eth interface.
Interface 0/0 -> Mikrotik ether1-BGP1
Interface 0/1 -> Mikrotik ether2-BGP2
Interface Vlan1 -> Mikrotik ether3-LAN
Cisco BGP config has
network 4.4.4.4 mask 255.255.255.240
network 5.5.5.5 mask 255.255.255.240
I am unable to add 4.4.4.4/30 and 5.5.5.5/30 into Mikrotik->BGP->Networks since those IP Networks are not assigned to any Mikrotik interface.
In this scenario, should i create a bridge on mikrotik with ether1 and ether2 as members and assign 4.4.4.4/30 and 5.5.5.5/30 onto the bridge interface?
The cisco router also has the following config
ip nat inside source static 192.168.1.111 4.4.4.6
ip nat inside source static 192.168.1.112 4.4.4.7
ip nat inside source static 192.168.1.113 5.5.5.7
ip nat inside source static 192.168.1.114 5.5.5.8
I would like to setup the same on Mikrotik using DNAT but Where should i assign the IP address of 4.4.46, 4.4.4.7, 5.5.5.7 and 5.5.5.8 on Mikrotik? The bridge interface?
Thanks!
lz1dsb
Re: migrating cisco to mikrotik
Fri Aug 01, 2014 2:28 pm
Dear Member
interface Vlan1
Thanks!
You can use a bridge interface in the RouterOS... if it's not assigned to any physical port or ports, it behaves pretty much like a Loopback interface in the IOS.
Regarding the NAT... check out this example&
http://wiki.mikrotik.com/wiki/Manual:IP ... Source_NAT
to give you an example in your case:
/ip firewall nat add chain=dstnat dst-address=4.4.4.6 \
to-addresses=192.168.1.111
/ip firewall nat add chain=srcnat src-address=192.168.1.11 \
to-addresses=4.4.4.6
Users browsing this forum: No registered users and 10 guests
