geebs
Enabling MPLS breaks OSPF
Fri Sep 19, 2014 7:04 am
Hello all,
I'm stuck on a very frustrating issue here.
I've added a couple of CCR routers to our Cisco network in an attempt to expand our MPLS network.
Our main routing protocol is OSPF, which works fine.
I've completed that setup and there are no issues.
Approx 15000 routes, routers humming along fine.
IPs changed to protect the innocent :)
Router 2
add address=10.85.2.4/24 interface=ether1 network=10.85.2.0
add address=113.6.25.252/32 interface=loopback0 network=113.6.25.252
add address=113.6.25.62/29 interface=vlan513 network=113.6.25.56
add address=113.6.25.26/29 interface=ether3 network=113.6.25.24
/routing ospf instance
set [ find default=yes ] router-id=113.6.25.252
/routing ospf interface
add authentication=md5 authentication-key=sssssss interface=vlan513 network-type=broadcast
add authentication=md5 authentication-key=sssssss interface=ether3 network-type=broadcast
add authentication=md5 authentication-key=1234 network-type=broadcast passive=yes
/routing ospf network
add area=backbone network=113.6.25.56/29
add area=backbone network=113.6.25.24/29
Router 1
add address=10.85.2.3/24 interface=ether1 network=10.85.2.0
add address=113.6.25.251/32 interface=loopback0 network=113.6.25.251
add address=113.6.25.25/29 interface=ether3 network=113.6.25.24
set [ find default=yes ] router-id=113.6.25.251
As soon as I enable LDP, everything goes crazy;
It's currently disabled.
Router 2
/mpls ldp
set lsr-id=113.6.25.252 transport-address=113.6.25.252
/mpls ldp interface
add accept-dynamic-neighbors=no disabled=yes interface=vlan513
add disabled=yes interface=ether3
Router 1
/mpls ldp
set lsr-id=113.6.25.251 transport-address=113.6.25.251
/mpls ldp interface
I lose OSPF connectivity, I lose router connectivity, it reports strange OSPF errors like;
Discarding packet: no neighbor with this source address
RouterId = 113.6.25.251
source = 113.6.25.25
As soon as I disable LDP, everything starts to work again.
MT support have advised me to disable OSPF for 60s when bringing up LDP, then re-enable it, however the same thing happens.
Has anyone encountered this ? or am I doing something wrong ?
I've been using the link as a guide;
http://wiki.mikrotik.com/wiki/MPLS_Lab_Setup
Thanks for your time.
nickshore
Re: Enabling MPLS breaks OSPF
Fri Sep 19, 2014 11:30 am
I think that you need your transportt-address to be the IP on eth3 not your loopback
Nick
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
nz_monkey
Fri Sep 19, 2014 11:45 am
A few things that stick out:
- You need an OSPF network that encompasses your loopback IP address e.g. 113.6.25.0/24
- Add an OSPF interface "all" that is set to passive, this combined with the above will advertise your loopback as an intra-area route.
- Manually specify OSPF interfaces for your LDP enabled interfaces set to broadcast or point to point.
Using your loopback address as the OSPF router-id is great
Likewise with LDP lsr-id and transport address.
If you get stuck, I am happy to help out on the phone.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
geebs
Sat Sep 20, 2014 7:26 am
Could you send me a PM or email me gweebo at gmail dot com.
Happy to pay you for your time :)
n21roadie
Wed Dec 17, 2014 3:13 pm
Interface "all" is that correct ?
N21roadie,
Network 100% MT for Now?
nz_monkey
Wed Dec 17, 2014 10:14 pm
Hi n21roadie.
You could just specify your loopback as a passive interface, but it is easier if you set the interface "all" to passive. This will then advertise any interfaces with an IP matching one of your "networks" as an intra-area route.
n21roadie
Wed Dec 17, 2014 10:45 pm
Hi n21roadie.
I am trying to get to grips with OSPF config?
What if OSPF Loopback interface is Dynamic and Passive?
And what about Wlan network type = PTP
and ether is network type = broadcast,
Does interface "all" to passive still apply
N21roadie,
nz_monkey
Thu Dec 18, 2014 10:22 am
Hi n21roadie.
Yes it does.
We use this extensively even on wireless ptp and ptmp links.
n21roadie
Thu Dec 18, 2014 1:02 pm
Yes it does.
Is it possible to post a sample of how you have setup OSPF Interfaces for both PTP and PTMP,
I must admit being somewhat baffled by how a loopback interface is dynamic in OSPF interface?
N21roadie,
Gombeen
Mon Dec 22, 2014 11:26 am
Hi n21roadie.
Having "all" interfaces as passive cannot be correct or is it?
Will this not effect the different network types being used by the interfaces (Wlan + Ether) and they are not passive?
nz_monkey
Tue Dec 23, 2014 12:00 pm
It is correct. You specify the interfaces you need to be broadcast/p2p manually. The "all" interfaces passive config catches other interfaces e.g. loopbacks, pppoe, customer links that match the "networks" and sets them as passive so those prefixes get advertised as intra-area routes.
Gombeen
Tue Dec 23, 2014 12:27 pm
Ok - let me get this - You set "all" interfaces as passive in /routing ospf interface but then other interfaces such as Wlan and Ether which are also listed in /routing ospf interface their setting will override the "all" interfaces as passive setting?
nz_monkey
Tue Dec 23, 2014 12:29 pm
Correct.
Gombeen
Tue Dec 23, 2014 2:02 pm
Correct.
When I add "all" interfaces as passive, Area="Unknown", State="Down", Network Type="broadcast"
Also should I add OSPF Loopback interface, at present its dynamic in /routing ospf interface
Gombeen
Tue Dec 23, 2014 10:16 pm
OK I tried interface "all" that is set to passive and this caused ospf to be confused,
I am convinced this is giving conflicting instructions to OSPF , first all ospf interfaces are passive and then for ether and Wlan ospf interfaces are not passive, the active interfaces did not over-ride passive setting and as mentioned OSPF got confused.
Users browsing this forum: No registered users and 10 guests
