Hi All,
I've got a CCR1009 with RouterOS 6.2.
I'm trying to establish a BGP connection to my upstream.
In winbox under peers it says the state is "connected" but I can't seem to get the microtik to establish a BGP connection.
I can telnet to my providers IP on port 179, and I can see traffic to 179 in IP > Firewall > Connections.
This command shows me nothing:
# routing bgp advertisements print
# /routing bgp peer print status
Prints:
Flags: X - disabled, E - established
0 name="transit-peer" instance=default remote-address=1.2.3.33 remote-as=12340 tcp-md5-key="" nexthop-choice=deroute-reflect=no hold-time=3m ttl=default in-filter=default-only out-filter="" address-families=ip default-originate=remove-private-as=no as-override=no passive=no use-bfd=no state=connect
Any ideas?
1.2.3.33 in my example is their side of the /30, with mine being 1.2.3.34.
I can ping both sides of the /30 (mine and theres) externally from a different ISP. Router is up but can't get BGP established.
Any ideas?
