exa
CPU usage issues with MPLS setup
Fri Feb 13, 2015 4:10 pm
I was trying to set up a basic MPLS/VPLS service on several smaller mikrotik routers in the network - they don't do anything special except for routing (~2000 routes from OSPF) on ethernets.
There seems to be a problem with the routers - whenever anything that seems to be connected with MPLS is "hit", there's a huge spike in CPU usage and the whole router slows down a lot. For example, enabling LDP results in ~10s 100% cpu. When there are any neighbors discovered, the CPU stays 100% all the time, profiling reports that around half of the time in MPLS and half in "routing".
Is there anything I missed, any reason for this behavior or something I'm doing totally wrong? Versions are 6.22 or newer.
Thanks,
-exa
IPANetEngineer
Trainer
Trainer
Re: CPU usage issues with MPLS setup
Fri Feb 13, 2015 5:34 pm
Which hardware models are you using?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
uottoni
Mon Oct 31, 2016 7:12 pm
I have a similar problem in this post: http://forum.mikrotik.com/viewtopic.php?f=14&t=114115
Please... I need help
Users browsing this forum: jatoledano and 25 guests
