MUM Europe 2020
amit213
CHR on QNAP NAS
Wed Aug 31, 2016 7:43 am
Normis, as far as the ability to move the license around between different CHR instances is concerned: Is this still valid if I were to purchase your CHR PI-10 licenses from a reseller?
You can't buy CHR licenses from a reseller. What you can do, is buy a "coupon" (a prepaid key) and then use that to pay for your CHR. But in reality this still means you make your own CHR keys.
That was very helpful. Thank you.
normis
Re: Cloud Hosted Router
Wed Aug 31, 2016 10:29 am
Is it possible to run CHR on qnap NAS server?
Not directly, you need to convert the CHR Image file first. Virtualization Station needs .vmx files to obtain the hardware configuration. We suggest that you import the CHR .vmdk files to the VMware Workstation first and convert it to the supported .ovf file format.
Users browsing this forum: No registered users and 1 guest
