divB
Metarouter unreliable
Sun Jan 15, 2017 7:36 pm
I am using metarouter (with OpenWRT) on RB450G with 3.24 and metarouter (not OpenWRT!) seems to be pretty unreliable:
Very often, when rebooting/shutting down, the router just hangs with Status "rebooting" or "shutting-down". There is no way no force a clean restart of a metarouter other than rebooting the whole RouterOS. This can't be a good idea but it's all that works for me.
Sometimes the metarouter would just crash, no ping possible and the console just prints nothing. I would not necessarily blame RouterOS for that but I blame RouterOS for the fact that I cannot restart the meta router other than forcing a reset of the entire host system!
Thanks!
expert
Re: Metarouter unreliable
Sun Jan 15, 2017 10:38 pm
What version of RouterOS you are using? 3.24 is version of bootloader, not RouterOS.
There have been some metarouter issues fixed in 6.38: *) metarouter - fixed startup process (introduced in 6.37.2);
divB
Sun Jan 15, 2017 10:56 pm
According to "/system resource print" it is version: 6.38 (stable).
It's really frustrating. Sometimes the meta router just crashes and the only way to get it back is to reboot the entire system.
sricci
Fri Jan 27, 2017 4:18 pm
The same happens for us, on the same platform (450G). We use metarouter quite extensively, but we found it to be unreliable and "picky". With a good amount of trial-error, we found a configuration which "mostly works": 6.36.4, be sure to run the latest routerboot also. We also reboot the devices (whole board, not metarouters) daily.
S.
divB
Tue Feb 14, 2017 11:53 pm
Thanks sricci. That's a sad reply.
I think at the very least, a force-reboot and force-stop of the meta routers should be implemented so that they can't hang. A metarouter should not be able to crash the whole host system :-(
expert
Wed Feb 15, 2017 9:47 am
Let me summarize metarouter (mr) status:
* mr is unreliable(?) Can you tell how you use mr?
* mr not supported on CCRs and RB3011UIas
* OpenWRT - no mr support in upstream project and builds provided by MK are obsolete
* OpenWRT project is stagnant, but there's a young fork called LEDE project
It looks like no good news :(
sricci
Fri Feb 17, 2017 11:37 am
We use it on RB450G to "virtualize" user CPE on some environments. Metarouter sees two interfaces: one is a dynamic interface bridged to the upstream interface on physical device (ether1, in this case), the other is a static interface (which may be ether2, 3, 4 or 5) which is the customer facing interface. There's some firewalling configured on the metarouter (nat masquerade rule, some mangle used for policing / shaping) and some queue tree rules. Nothing fancy. We discovered that layer7 matcher in the metarouter firewall can crash the whole device under some traffic patterns, since we dropped them from configuration the stability has improved a bit...but it's not here yet. It's quite frustrating because we didn't find a way to reproduce the issue, sometimes "just happens"; we're evaluating solutions from other vendors which is unfortunate to us, because we have 4k+ mikrotik CPEs installed and the metarouter is seen by our system just as another CPE (so we can use the same management / provisioning tools we used to date).
No, it's not.
I can't speak about openwrt support since we never used it.
CyB3RMX
Wed Jul 19, 2017 7:48 pm
What do you use then?
Users browsing this forum: No registered users and 20 guests
