What do you mean with SCSI controller? Works fine with SCSI. Example on VirtualBox:And please, make support of SCSI\SATA controller, not IDE
[admin@MikroTik] > /system resource print
uptime: 3m56s
version: 6.41rc20 (testing)
build-time: Aug/29/2017 06:41:04
free-memory: 14.9MiB
total-memory: 32.2MiB
cpu: Intel(R)
cpu-count: 1
cpu-frequency: 1899MHz
cpu-load: 0%
free-hdd-space: 32.1MiB
total-hdd-space: 63.5MiB
write-sect-since-reboot: 424
write-sect-total: 425
architecture-name: x86_64
board-name: CHR
platform: MikroTik
[admin@MikroTik] > /system resource pci print
# DEVICE VENDOR NAME IRQ
0 00:14.0 LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320 SCSI (rev: 0) 9
1 00:07.0 Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev: 8) 9
2 00:06.0 Apple Computer Inc. KeyLargo/Intrepid USB (rev: 0) 11
3 00:04.0 InnoTek Systemberatung GmbH VirtualBox Guest Service (rev: 0) 9
4 00:03.0 Intel Corporation 82540EM Gigabit Ethernet Controller (rev: 2) 10
5 00:02.0 InnoTek Systemberatung GmbH VirtualBox Graphics Adapter (rev: 0) 11
6 00:01.0 Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II] (rev: 0) 0
7 00:00.0 Intel Corporation 440FX - 82441FX PMC [Natoma] (rev: 2) 0
He probably meant generating VMDK images in a proper format so it can easily be used with ESXi without having to convert it first. (The VMDKs from your download page can only be imported as IDE, whereas converted images work fine as SCSI as well, hence the wording.)What do you mean with SCSI controller?[/code]And please, make support of SCSI\SATA controller, not IDE
I hope you are aware that the released images are not really compatible with ESXi and need to be converted again by the user.In our build environment we use Qemu tools to convert images to various formats (qemu-img convert), including to VMDK. To convert a VMDK image created by Qemu to ESXi compatible format, VMWare tools (vmkfstools) are necessary. They are provided together with the ESXi server so you can do it on your ESXi. Instructions how to install the CHR on ESXi are available here - https://wiki.mikrotik.com/wiki/Manual:C ... e_ESXi_6.5
OK you wanted features suggestions.In our build environment we use Qemu tools to convert images to various formats (qemu-img convert), including to VMDK. To convert a VMDK image created by Qemu to ESXi compatible format, VMWare tools (vmkfstools) are necessary. They are provided together with the ESXi server so you can do it on your ESXi. Instructions how to install the CHR on ESXi are available here - https://wiki.mikrotik.com/wiki/Manual:C ... e_ESXi_6.5
I totally agree that OVF is the only way to go for releasing virtual appliances. Mikrotik team should have a look into this.OK you wanted features suggestions.In our build environment we use Qemu tools to convert images to various formats (qemu-img convert), including to VMDK. To convert a VMDK image created by Qemu to ESXi compatible format, VMWare tools (vmkfstools) are necessary. They are provided together with the ESXi server so you can do it on your ESXi. Instructions how to install the CHR on ESXi are available here - https://wiki.mikrotik.com/wiki/Manual:C ... e_ESXi_6.5
Ditch all the above and distribute CHR as an ovf like a normal virtual appliance rather than all this total mess you just mentioned.
Guys, I think CHR should be kept clean, as it is now. It's damn small, and you can backup and restore your vm image in disaster recovery scenario quickly.
Thats virtual router, not full blown linux machine. Thats why routeros (beside its bugs, sometimes) is rock solid. Adding too much stuff will end in sw size grow, bugs, attack vectors and much more not predicted situations.
Better focus on networking/drivers/vmtools stuff.
Why you cant just run separate linux with dockers? Since you already running vm environment. It will be even better - you can assign cpu priorities, and in cause of web server or other docker service DoS, you will have just web service down, not whole CHR machine.
From my side, sriov support, vmtools: safe shutdown, memory queiescent.
Plus, maybe some firewall matcher to allow traffic to/from licencing server ( need add static ip now, hope it will not change soon).
IDS takes significant amount of cpu. Thats ridicolous idea.Guys, I think CHR should be kept clean, as it is now. It's damn small, and you can backup and restore your vm image in disaster recovery scenario quickly.
I agree. Many request a swiss army router that can act as a PBX and control their vacuum cleaner, toggle the lights on their fish tank and other things that have no place in a router.
Some perhaps are more into saving money by requesting Mikrotik put everything they need into the software. Seriously if your a business you will have a separate server for PBX and non routing functions.
Some would like it to be more of a UTM appliance which while probably possible would take an amazing amount of development and would require Mikrotik to grow significantly to support such a product and no doubt enter us into the subscription based pricing model to make it worthwhile for them.
Users can adjust parameters after they installed the OVF. That is not a problem.Regarding OVF.
You really think there's a "one for all" configuration that will satisfy most of the users?
Ok, but does it work in the OVA that we have provided earlier (https://www.mikrotik.com/download/share ... S_CHR1.ova)? Can it be imported in the ESXi in the manner that you require without any additional steps?Users can adjust parameters after they installed the OVF. That is not a problem.Regarding OVF.
MikroTik should be able to define parameters like disk size, amount of memory, required devices etc as they are also
able to build routers according to the RouterOS requirements. When users want to set more memory, they can do so.
The reason that an OVF is required is mainly to get a correct definition of the disk image that is compatible between
RouterOS and ESXi. As it is now, it has to be converted before it works reliably. When this is not done correctly, it
can appear to work but a few days later the router crashes when it tries to write something to disk.
tested it - works fine, but disk still connected as IDE.Ok, but does it work in the OVA that we have provided earlier (https://www.mikrotik.com/download/share ... S_CHR1.ova)? Can it be imported in the ESXi in the manner that you require without any additional steps?Users can adjust parameters after they installed the OVF. That is not a problem.Regarding OVF.
That is what makes it so nasty! It will fail after some time. And that does not happen when youtested it - works fine, but disk still connected as IDE.
I can change required HW parameters after deploying, no problem for that.
As mentioned you put the minimum or recommended resources for CHR and users will adjust them according to their needs.Regarding OVF.
There might be various scenarious how our users would use the CHR. In the OVF there's already specified RAM, HDD, Interface count, etc. - and it might be different for different use cases. We actually have already created such one off template (https://www.mikrotik.com/download/share ... S_CHR1.ova). And in response we got requests to adjust the parameters. You can still take that OVA file, upgrade RouterOS to the newest version and use it.
That's it, thanks!Please check whether this OVA suits your needs and can be deployed on the ESXi without any additional steps:
* It has SCSI drive
* It has been exported from the ESXi
https://www.mikrotik.com/download/share ... R_SCSI.ova
If this suits your needs we'll see how to automate the creation of such OVA file upon RouterOS version releases.
So it works as expected, yes?That's it, thanks!Please check whether this OVA suits your needs and can be deployed on the ESXi without any additional steps:
* It has SCSI drive
Yes, deployed virtual machine have SCSI controller by default.So it works as expected, yes?That's it, thanks!Please check whether this OVA suits your needs and can be deployed on the ESXi without any additional steps:
* It has SCSI drive
Just tested the OVA on latest ESXi 6.5 and works fine - thanks! I'm able to adjust the hardware settings of the VM after importing as required.Please check whether this OVA suits your needs and can be deployed on the ESXi without any additional steps:
* It has SCSI drive
Indeed.@kasparskr
For OVA and ESXI
it don't know if it's possible to be able to select a OVA compatible version, since your ova is generated on a newest version, so who use esxi < 5.5 it is unable to run it
I confirm it's working fine on ESXi 5.5.Please check this OVA. HW version has been changed to 10 and should work on the ESXi 5.5. It still works on the ESXi 6.5.
https://www.mikrotik.com/download/share ... 6_40_3.ova
Our procedure is as follows:
* We convert the VMDK file that is currently available on the download page to the the thin format (with vmkfstools on the ESXi machine)
* Create a VMX file with basic parameters
* Register it to the ESXi (vim-cmd solo/registervm)
* Then from a remote machine using 'ovftool' we generate the OVA
For the VM name "displayName" parameter is used.
UPDATE: Adjusted the VMX, added "annotation" field which shows up as "Notes"
This is wonderful! Even if you don't plan to keep doing this process for future versions can you please make sure the link is available on your download page anyway? Install the OVA and upgrade only works if we can find the OVAPlease check this OVA. HW version has been changed to 10 and should work on the ESXi 5.5. It still works on the ESXi 6.5.
Thanks! We plan to add it to the download page and publish automatically with each new RouterOS release.This is wonderful! Even if you don't plan to keep doing this process for future versions can you please make sure the link is available on your download page anyway? Install the OVA and upgrade only works if we can find the OVAPlease check this OVA. HW version has been changed to 10 and should work on the ESXi 5.5. It still works on the ESXi 6.5.
Indeed. You can 'fix' the VM directory by migrating it to another storage and back.The actual version will change over time and this name cannot really be changed anymore.
(you can rename the VM but inside the VM directory the vmdk files will keep the original name - confusing)
Ok, the web interface does not suggest any name, the VM name field is blank when deploying an OVA:Yes. The .ova of course can have a version in its name, but the name suggested in the wizard when importing the .ova is better left generic.
(and the note probably as well, although that can easily be edited afterwards when desired)
Is that a change that has been made? Or maybe it depends on VMware version and/or procedure used?Ok, the web interface does not suggest any name, the VM name field is blank when deploying an OVA:
Please try the last version I posted - https://www.mikrotik.com/download/share ... 6_40_3.ova, it shouldn't have the version number in the suggested VM name.Is that a change that has been made? Or maybe it depends on VMware version and/or procedure used?Ok, the web interface does not suggest any name, the VM name field is blank when deploying an OVA:
In my case it suggested a name that included the version number.
Just leave it here: https://www.youtube.com/watch?v=PivpCKEiQOQPlease clarify how you would use it and whyThats greatCHR should run containers, docker or whatever.
+1
+1
I would like to see a CHR ISO image.We see that the CHR is getting quite popular, so we would like to ask everyone, what new features would you like to see in the future? List your top requests for Cloud Hosted Router (CHR) and virtual machines that we do not have yet.
How is this different from the normal x86 install that has literally been an option for over a decade? Download: https://mikrotik.com/download (X86 section, right after ARM - the CD image is literally an ISO as you requested) and license info: https://wiki.mikrotik.com/wiki/Manual:L ... nse_Levels (Non-CHR X86 licenses are feature-based, not port-speed-based). CHR was introduced because the basic X86 version assumed it was running on bare metal, and wasn't properly suited for being installed as a VM.I would like to see a CHR ISO image.
I would like the ability to directly install a CHR ISO onto a server (skipping & not using a hypervisor). Thus a CHR could have direct access to all hardware devices and eliminate the need for a hypervisor.
Fist - x86 is a 32-bit systemHow is this different from the normal x86 install that has literally been an option for over a decade? Download: https://mikrotik.com/download (X86 section, right after ARM - the CD image is literally an ISO as you requested) and license info: https://wiki.mikrotik.com/wiki/Manual:L ... nse_Levels (Non-CHR X86 licenses are feature-based, not port-speed-based). CHR was introduced because the basic X86 version assumed it was running on bare metal, and wasn't properly suited for being installed as a VM.I would like to see a CHR ISO image.
I was not aware that the X86 downloads were 32 bit only. Every one of your other points is based on this issue, so it really sounds like what you are asking for is an X86 install that is 64-bit. I understand at this point it may be easier to base this off of the CHR code, but this isn't a feature request for CHR itself. Also, given the "raw image" that is available, can't you just transfer, e.g. with dd, this to a hard drive? ethernet driver support might be a bit limited based on whatever is in the kernel, but at least this way you'd have a 64 bit OS on bare metal?Fist - x86 is a 32-bit system
ClickI was not aware that the X86 downloads were 32 bit only. Every one of your other points is based on this issue, so it really sounds like what you are asking for is an X86 install that is 64-bit. I understand at this point it may be easier to base this off of the CHR code, but this isn't a feature request for CHR itself. Also, given the "raw image" that is available, can't you just transfer, e.g. with dd, this to a hard drive? ethernet driver support might be a bit limited based on whatever is in the kernel, but at least this way you'd have a 64 bit OS on bare metal?Fist - x86 is a 32-bit system
Show me any Tilera / ROS system that can btest udp to 127.0.0.1 and get faster than 20 gig (or even half of that or even half of half of that) - there is no such thing. My ol clunker several years old CHR on a Xeon ESXi system can hold 19 gig all day long. Taking it to newer CPUs and running bare metal should hit 30+ gig on a btest to 127,0,0,1I would agree that a x86_64 ISO would be useful. I utilize several CHR and I do like them. The license check in I do find annoying. Kinda has a Microsoft feel.
The Elephant in the room is why there is not a CCR that has the balls to handle the more demanding tasks quickly and reliably. I don't think it matters if they have 400 cores if the frequency is only 1GHz or 1.2GHz
Perhaps if they could offload BGP to a FPGA or something. I would imagine that if Tilera GX came in 3GHz multicore we would not be complaining as much and CHR and x86_64 would not be that huge of an issue.
you may just convert your x86 installation to x86_64Yea - I've been wanting to transfer a virtual CHR hdd system to a physical system and dump the hyper-visor and try running it on bare metal. I think it would work.
What do you need it for on a bare metal?Second - x86 does not have any paravirtual support
It's not that simple in reality. Being that straightforward shows to me that you do not really understand how this 32bit vs 64bit stuff works.Sixth - 64-Bit operating systems also support 64-bit access to memory (faster)
Seventh - 64-Bit systems also can also use more efficient 64-bit compilers and use 64-bit instructions (faster again)
Eighth - I believe 64 bit systems also have additional registers (more registers than 32-bit systems) (again faster again)
Ninth - a fully 64-bit compiled system can process more instructions (some new 64-bit instructions) which can result in fewer CPU clock cycles need to perform a function. (((64-bit hardware can easily out-run 32-bit hardware with both CPUs clocked at the same CPU clock speed.
WAT?Eleventh - a 32-bit system running 32-bit code can use twice the CPU/memory read/write clock cycles as a 64-bit system running 64-bit code. (again - lots of these - faster again)
I'd take it if your are only looking for something to run btest on. Comparing how fast btest is on a given hardware is just that- comparing the btest performance. Btest is known to be (a) single-threaded and (b) highly inefficient (even Mikrotik stuff have admitted that here multiple times). Result of such comparison will have no direct indication of how fast the other tasks run on the same hardware.Show me any Tilera / ROS system that can btest udp to 127.0.0.1 and get faster than 20 gig (or even half of that or even half of half of that) - there is no such thing.
We have several places where we run CHR on AWS, both as central location for management/vpn-termination/dude and to use RouterOS for VPN-tunnels instead of having to struggle with the AWS VPN service.
To take this concept further, we would really be helped by the ability to install CHR on KVM and Google Cloud as well.
I second that for sure!!!Make CHR to run on barebone switches. http://www.edge-core.com/productsInfo.p ... 143&id=264
yes this is important.Please support virtio SCSI storage controllers, see viewtopic.php?f=15&t=120413
I guess it will always be possible to craft some environment in which a binary-only distribution cannot run.Currently i have some VM provided by Bandwagon,which use a disk driver so CHR can not run on it.
There is hugge difference between "not working, becouse of difficult environment" and "not working, becouse of lack of one of the most important, mainline drivers". Look at similar problem at VyOS: https://phabricator.vyos.net/T389I guess it will always be possible to craft some environment in which a binary-only distribution cannot run.Currently i have some VM provided by Bandwagon,which use a disk driver so CHR can not run on it.
The question is if it is worth the trouble to cater for that, or one just has to wait until all the "incompatible" and "difficult" environments just vanish from the market because customers no longer want to put up with those difficulties.
It's not only my whim to run CHR on KVM with SCSI-virtio. Look at the problem like this: KVM VPS hosting is cheapest full virtualisation on the market. If I want to provide homogenicall network environment with Routerboard devices It's natural to use CHR. If I can't use it becouse using obslate mode (driver) of Virtio storage (look closely at: https://pve.proxmox.com/wiki/Paravirtua ... or_Windows ) everything is going to be more and more complicated (more expensive VPS with vmware or diffrent OS).Difficulty level Easy (less than an hour)
VM inside VM? Are you serious?Please add Metarouter
Servers have had hardware support for this for ages. It is actually not as bad as it first sounds, but as always it depends on the application.VM inside VM? Are you serious?Please add Metarouter
+1 I think this should be a priority https://github.com/vmware/open-vm-toolsSmall web server, if MikroTik would want to give us something like that, would also make sense for any other RouterOS, not just CHR. And it's also true for pretty much anything else you can think of (any service and such).
CHR needs VM-specific stuff. VM tools being a nice example. Or all kinds of virtual drivers. And VMDK disks distributed as SCSI instead of IDE would also be nice.
+1Desired features:
- Graceful shutdown/reboot on XenServer
- XenMotion between hosts without freezing MikroTik router. (currently will cause MikroTik to lock up)
Can you please share with us what you mean with 'I made a Mikrotik based SD-WAN'. Do you mean: A -> some SD-WAN -> Mikrotik router -> some connectivity -> Mikrotik Router -> some SD-WAN -> B . Or you mean some directly integrated solution with roureros / maybe meta router ?I doubt you will see such features. Would it be cool? Absolutely! I would imagine you will grow old and die before you see the requested features
I made a Mikrotik based SD-WAN solution for a client that works quite well. I spent a month in the lab testing various scenarios to get the desired function. I think Pepwave & Mushroom are some possibilities if you are looking for manufactures that currently support SD-WAN solutions.
THANK YOU MIKROTIK!Good to see MikroTik are responsive.
Xen Tools and VM Tools are now available in 6.42RC. The "current" build of 6.42 can't come fast enough for me!
Hi thank allot i will post a print on your topic for dont fload this topicDon't ask about CHR. I think that this product isn't interesting for MT developers as in the beginning of existence.
To bypass your problem, use ISO of your favourite live linux (without installation) and my guide:
viewtopic.php?t=120413
Keep in mind if your cloud provider (ramnode) use current version of KVM, they probably forcing to use VirtIO-SCSI.... and CHR currently doesn't supports it.
viewtopic.php?f=15&t=124905&start=100#p626094
I will be appreciated if you will test it.
For easier installing we have introduced CHR in OVA format, it is available on the download page.MT Support
is so difficult to create an iso version of CHR ?
because some KVM like ramnode dont allow to use virtual disk only iso
Could you tell us please when is planned to add VirtIO-SCSI boot support?ISO is something to make a CD from. Why don't you simply migrate to a cheaper and more modern Cloud provider?
Linode can do it, Hetzner can do it. More powerful machines, SSD disks and cheaper price:
https://www.hetzner.com/cloud
The kernel used by RouterOS v6.x does not support it, so you can probably safely say: not until RouterOS v7.Could you tell us please when is planned to add VirtIO-SCSI boot support?
We'll see about that.CHR would need to be able to boot from Virtio SCSI. Not a good example normis.
Is that what you are looking for?*) chr - added "virtio-scsi" driver on KVM installations;
Can we run CHR in Google Cloud now?
What's new in 6.42rc28 (2018-Feb-16 07:02):
*) chr - added support for Hyper-V ballooning;
*) chr - added support for Hyper-V guest quiescing;
*) chr - added support for Hyper-V host-guest file transfer;
*) chr - added support for Hyper-V integration services;
*) chr - added support for Hyper-V static IP injection;
*) chr - added support for NIC hot-plug on VMware and Xen installations;
*) chr - fixed additional disk detaching on Xen installations;
We would like to receive your comments about these CHR features.
