zaidm1988
CHR tx limit on 1199M rx limit up to 9G install on esxi 6
Tue Mar 06, 2018 9:14 am
hi every body
i have i problem in my chr
when i run bandwidth test tx still on 1119 or less but rx work normally and the traffic up to 10G
i test that on sfp 10G
i test that on bonding
and i open ticket with mikrotik support before 4 days without any response
Pic
https://drive.google.com/open?id=1moym6 ... hDaVHtCklj
note
my license P10 95$
jarda
Re: CHR tx limit on 1199M rx limit up to 9G install on esxi 6
Tue Mar 06, 2018 1:36 pm
Btest is single threaded so it can not describe the routing performance of the device. If you would like to test the performance, use two devices on sides as traffic generators and put tested equipment in the middle of them.
zaidm1988
Wed Mar 07, 2018 2:43 pm
thanks for your replay
i put it in real traffic but i see the same issue TX traffic down
Steveocee
Thu Mar 08, 2018 1:12 pm
Have you registered the CHR to your account? It has a limitation if it is installed and not activated to a MikroTik account.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
TomjNorthIdaho
Forum Veteran
Forum Veteran
Fri Mar 09, 2018 7:34 am
btest on a chr with a 10-gig network card will do 9.999 Gig through the network to another physical box
btest on a chr to another chr hosted on the same hypervisor (with mnxnet3 ) will hit 17 to 19+ gig or more depending on the physical hardware
North Idaho Tom Jones
TomjNorthIdaho
Forum Veteran
Forum Veteran
Fri Mar 09, 2018 7:36 am
Yup - if not a licensed CHR - it will run sllooowwww ( 1 or 2 meg max I think )
zaidm1988
Sat Mar 10, 2018 9:14 am
thnx for all
my CHR license P10 and only limit on TX or RX on both i install CHR on
esxi un limited core
my vm
64 core
128 Ram
i have 3 network card i try E1000-E100e-vmnex3
2 SFP+ HP card
4 Ethernet 1G each interface
builtin card hp 4 Ethernet two interface 1G and two interface 10G
I have a problem with each traffic more than 1G
zaidm1988
Sat Mar 10, 2018 9:26 am
zaidm1988
Sat Mar 10, 2018 9:54 am
i want 10G up&down per interface
p10
p10 (perpetual-10) license level allows CHR to run indefinitely. It is limited to 10Gbps upload per interface. All the rest of the features provided by CHR are available without restrictions. It is possible to upgrade p10 to p-unlimited After the upgrade is purchased the former license will become available for later use on your account.
jarda
Sat Mar 10, 2018 10:35 am
Isn't one core exhausted by btest? Really, do not use btest instead real traffic generator. Do not bother tested device by running btest.
zaidm1988
Sat Mar 10, 2018 12:12 pm
i check it with real traffic and same issue
jarda
Sat Mar 10, 2018 12:34 pm
I am not able to see your picture in necessary details. Cannot say more than that. Have you checked the cpu?
zaidm1988
Sat Mar 10, 2018 1:09 pm
jarda
Sat Mar 10, 2018 4:16 pm
What is on the way between those two devices? How their processors look like during that load? How this device look like when the traffic generators are neighbouring pushing the traffic through? And don't use btest if you would like to get serious results.
Users browsing this forum: No registered users and 3 guests
