donsergio
Install Mikrotik on a X86 server
Thu Jul 12, 2018 5:16 pm
Hi, have Mikrotik any restriction of lan chipset to install it on a X86 server?
Can I install it on any server?
Thanks!!
Steveocee
Re: Install Mikrotik on a X86 server
Thu Jul 12, 2018 5:45 pm
You can but it is recommended to use CHR and visualise. Driver support is better for CHR, CHR supports 64bit and licensing is better (and you can move licenses with CHR).
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
BartoszP
Thu Jul 12, 2018 6:20 pm
Visualise should be "virtualize".
Installing to bare metal has many problems and it seems that Mikrotik is focusing on virtual versions instead on native ones.
Real admins use real keyboards.
donsergio
Thu Jul 12, 2018 6:59 pm
Hi, then the better way is?
How I can virtualize... I has a dedicated with centos 7
Has any tutorial to do it?
Thanks!!
Steveocee
Thu Jul 12, 2018 7:32 pm
Lol Damn autocorrect! Yes I meant virtualise.
If you are asking about bare metal install then can I assume you have a spare machine in which case maybe something like ESXi which is free and quite easy to get to grips with. There is an OVA you can import straight in to get running.
Users browsing this forum: No registered users and 3 guests
