ukzerosniper
CHR 6.42.6+GNS3 = No RoMON
Tue Jul 24, 2018 4:59 pm
Hi Guys,
I cannot get RoMON to work in CHR 6.42.6 when running in GNS3.
I can connect to the RoMON server without issue, but it cannot connect to the other routers.
Has anyone else experienced this and been able to resolve it?
Thanks.
tomaskir
Trainer
Trainer
Re: CHR 6.42.6+GNS3 = No RoMON
Tue Jul 24, 2018 6:28 pm
RoMON uses a MKT proprietary L2 protocol.
The default simulated switches in GNS3 only forward Ethernet frames.
This is why you are not able to use RoMON, or other non-standard L2 protocol in GNS.
Work-around is not to use the GNS3 "switch" object to connect your simulated MKTs, but use something else to do the switching.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
miguelangelfelix
Trainer
Trainer
Thu Oct 11, 2018 7:20 am
I have this problem too with gns3 and vmware esxi.
i used “eve-ng” before and it just works with RoMon excellent.
chubbs596
Thu Nov 29, 2018 3:28 pm
Hi Guys
I have the same problem now with RoMON on Vmware esxi 6.7 , RoMON was working on esxi 6.5
Any Ideas how to fix this issue?
infex987
Tue Dec 04, 2018 5:52 pm
the solution is to change the default configuration of the ethernet interface that comes by default virtio-net-pci to some intel or realtek interface I recommend using intel gigabyte ethernet (e1000)
Retral
Wed Jan 02, 2019 3:37 am
Kudos to the quoted guy. I could not for the life of me get RoMon working on CHR's, once I changed from virito-net-pci to intel everything is working flawlessly so far. I'm just wondering if there is anyone that can shed some light on why the virito-net-pci driver doesn't work?
Users browsing this forum: No registered users and 10 guests
