mstsc
CHR disk size
Fri Nov 16, 2018 12:20 am
Hi!
Setup CHR in my VPS. HDD space 50GB. After first boot - router os resize disk, remains 15GB.. Where is the rest of the disk space?
Sanity
Re: CHR disk size
Thu Nov 22, 2018 11:25 am
50gb? What for to start with? I run CHR on a 128MB disc. That is MEGAbytes, not GIGAbytes. What are you storing on 50gb?
Kindis
Re: CHR disk size
Thu Nov 22, 2018 11:46 am
Hi!
Had a vague memory that they limited the size of CHR disk in a release so I made a search in the change logs and I found the following:
What's new in v6.40 (2017-Jul-21 08:45):
*) chr - maximal system disk size now limited to 16GB;
mstsc
Re: CHR disk size
Mon Nov 26, 2018 2:52 pm
Support answered - there are no disk limitations. Who is right?
Steveocee
Re: CHR disk size
Mon Nov 26, 2018 4:47 pm
Maybe both are correct?
System disk size can only be up to 16GB however that does not stop you adding additional disk at a size of your choice?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
mstsc
Re: CHR disk size
Tue Nov 27, 2018 2:47 am
however, RouterOS does not leave me the opportunity to manage disk space. How do I add a disk?
Steveocee
Re: CHR disk size
Tue Nov 27, 2018 10:42 am
If you add it through ESXi as you normally would then it should present in RouterOS as "Disk1" or similar.
Users browsing this forum: No registered users and 4 guests
