vecernik87
Forum Veteran
Forum Veteran
CHR does not transmit frames with VLAN tags from bridge
Thu Jan 31, 2019 2:34 am
I suspect this is not version related. I am experiencing similar behavior on 6.42.7 and 6.44beta61 (and anything i tried between) running in HyperV
I actually did some digging and hopefully I narrowed it down to a simple statement:
receiving and transmitting untagged data between bridge and hypervisor's virtual ethernet interface work
receiving and transmitting VLAN tagged data between VLAN interface and hypervisor's virtual ethernet interface work
receiving and transmitting VLAN tagged data between bridge and hypervisor's virtual ethernet interface DOES NOT work
(there is no VLAN filtering on bridge enabled, even though it seems like obvious cause)
Now let me prove it.
In HyperV, I have properly configured vlan trunking:
PS C:\WINDOWS\system32> Get-VMNetworkAdapterVlan
VMName          VMNetworkAdapterName Mode  VlanList
dut             eth1             Trunk 0,1-4094
tester          eth1             Trunk 0,1-4094
(dut is the Device Under Test where I will prove the bug, tester is doing all pings (arp requests) and is configured practically same way, only difference is that tester does not have any bridge)
Similarly, I have enabled MAC spoofing on both adapters.
Then I have CHR2 (dut) with following config:
   add fast-forward=no name=bridge1
   set [ find default-name=ether1 ] disable-running-check=no
   set [ find default-name=ether2 ] disable-running-check=no name=ether2-management
/interface vlan
   add interface=ether1 name=vlan1 vlan-id=98
   add bridge=bridge1 hw=no interface=ether1 trusted=yes
   set discover-interface-list=none
   add address=10.99.0.3/24 interface=ether1 network=10.99.0.0
   add address=10.99.1.3/24 interface=bridge1 network=10.99.1.0
   add address=10.99.98.3/24 interface=vlan1 network=10.99.98.0
/ip dhcp-client
   add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=ether2-management use-peer-dns=no use-peer-ntp=no
/system identity
   set name=dut
Pretty simple, right? (I promise, I didn't skip anything, this is literary blank CHR just for this test) Lets completely ignore Ether2 (it is just for management purpose) and focus on ether1, bridge1 and vlan1
With this config, I can easily ping any address. All of them are responding fine (even though ether1 shouldn't have address as it is slave...) I am actually using ARP ping to make sure that no ARP shenanigans will affect my test:
[admin@tester] > ping 10.99.0.3 arp-ping=yes interface=ether1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 00:15:5D:C9:30:0B                                 1ms
    1 00:15:5D:C9:30:0B                                 0ms
    2 00:15:5D:C9:30:0B                                 0ms
[admin@tester] > ping 10.99.1.3 arp-ping=yes interface=ether1
    0 00:15:5D:C9:30:0B                                 0ms
    2 00:15:5D:C9:30:0B                                 2ms
[admin@tester] > ping 10.99.98.3 arp-ping=yes interface=vlan1
    1 00:15:5D:C9:30:0B                                 1ms
    2 00:15:5D:C9:30:0B                                 3ms
With this, I confirmed that my HyperV settings is right and does not limit VLANs.
Now, lets change config to create the bug:
[admin@dut] > /interface vlan set vlan1 interface=bridge1
Thats all folks. All I did is moving my vlan1 from ether1 to bridge1. Shouldn't make difference, right? Actually - the previous configuration was practically a misconfiguration. (This suggest that packet flow in CHR does not behave same way as in normal routers. According to the description, VLAN on slave interface should not work at all because all traffic should be forwarded straight to the bridge)
Anyway, lets look what results I get now:
    0 00:15:5D:C9:30:0B                                 4ms
    2 00:15:5D:C9:30:0B                                 4ms
    0 00:15:5D:C9:30:0B                                 2ms
    1 00:15:5D:C9:30:0B                                 7ms
    0 10.99.98.3                                              timeout
    1 10.99.98.3                                              timeout
    2 10.99.98.3                                              timeout
ohhh, where is my VLAN? Why is it not responding? There is no VLAN filtering on the bridge and it should work (at least it works on any physical router which I tested around)
Lets look at packet sniffers. We have 4 points of interest: vlan1 in dut, bridge1 in dut, ether1 in dut and finally ether1 in tester:
[admin@dut] > tool sniffer quick interface=vlan1
INTERFACE     TIME    NUM DI SRC-MAC           DST-MAC           VLAN   SRC-ADDRESS
vlan1        10.71      1 <- 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF        10.99.98.2: who has 10.99.98.3?
vlan1        10.71      2 -> 00:15:5D:C9:30:0B 00:15:5D:C7:30:0D        10.99.98.3: at 00:15:5D:C9:30:0B
[admin@dut] > tool sniffer quick interface=bridge1
bridge1      7.237      1 <- 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF 98     10.99.98.2: who has 10.99.98.3?
bridge1      7.237      2 -> 00:15:5D:C9:30:0B 00:15:5D:C7:30:0D 98     10.99.98.3: at 00:15:5D:C9:30:0B
[admin@dut] > tool sniffer quick interface=ether1
ether1       5.187      4 <- 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF 98     10.99.98.2: who has 10.99.98.3?
ether1       5.187      5 -> 00:15:5D:C9:30:0B 00:15:5D:C7:30:0D 98     10.99.98.3: at 00:15:5D:C9:30:0B
[admin@tester] > tool sniffer quick interface=ether1
eth2-jcw                     0.991      1 -> 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF 98     10.99.98.2: who has 10.99.98.3?
eth2-jcw                     2.051      2 -> 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF 98     10.99.98.2: who has 10.99.98.3?
eth2-jcw                     3.081      3 -> 00:15:5D:C7:30:0D FF:FF:FF:FF:FF:FF 98     10.99.98.2: who has 10.99.98.3?
With this, I just confirmed that dut can see both ARP-Request and ARP-Reply on ALL interfaces in, but those ARP-Replies do not really leave the CHR (it just pretends to be TXed from Ether1)
Now, why do I think it is fault of CHR? Elementary, my dear Watson - there is no difference in frame, whether it goes vlan1->ether1 or vlan1->bridge1->ether1. Due to that, anything else except dut (for example HyperV, tester, host OS...) can't possibly know, there was such change in topology.
Same thing happens when (instead of vlan1) communication flows for example through bridged EoIP from some remote device. As long as it is not tagged, it works. Once it gets tagged and goes through a bridge in CHR to virtual ethernet, it never leaves...
It also does not matter if the "tester" device is virtual or physical.
As always, when I find some reportable bug, I would like to ask you - clever members of this community - to look at it and point out any possible issue which I missed.
This time, situation is really simple and easily replicable - can anyone confirm/deny this bug?
anav
Re: CHR does not transmit frames with VLAN tags from bridge
Tue Mar 19, 2019 6:38 pm
Not to worry its a virtual bug, not real! ;-)
Any configuration with routerOS and vlans that I have worked with has bridge vlan-filtering=yes???
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Steveocee
Sat Apr 06, 2019 10:50 pm
What happens if you change the vlan ID? Try using anything other than 1.
Sounds mad but in my mind I had a problem similar and it was caused by this and we’re talking about MikroTik.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
vecernik87
Forum Veteran
Forum Veteran
Sun Apr 07, 2019 4:23 am
I almost lost hope that anyone would be interested in this :D Thanks gents for replies.
That applies if you want to do vlan filtering (i.e. you want to tag/untag stuff). In my case, I have vlan-filtering=no on purpose, because all ports should behave as trunks. This is similar to normal dumb-switch behavior, which just forwards all frames based on MAC, no matter what VLAN ID is set.
In addition, keep in mind that same configuration works on physical routerboards.
I never use 1. Its just default name of the interface. All my tests were conducted on several different ID's. To be specific 1016, 250, 100, 99 and finally 98 which i used purely for this test with fresh installation of CHR
Could you please describe it bit more?
- What hypervisor?
- was your VLAN interface bound to bridge or directly on Ethernet interface?
It might have something similar but I am pretty sure that this is very particular and easily replicable bug.
All I need to know is, whether someone else can replicate it or if it works for everyone except me.
Simply said - if VLAN interfaces work when their master-interface is Ethernet but don't work when their master-interface is bridge, then you most likely replicated the bug (but please, share your config so we can compare and make sure)
vecernik87
Forum Veteran
Forum Veteran
Sun May 12, 2019 5:33 am
update: I just got chance to test this config on ESXi 5.5 and surprise-surprise, it works! (obviously, vlans and promiscuous mode must be enabled on virtual switch)
coelliale
Thu Jul 02, 2020 8:46 am
the problem with chr and hyper-v is still here :-(
RouterOs 6.47 on windows 2019, vlan on bridge are lost
I will try on v7 beta..
Alessandro
coelliale
Sat Sep 05, 2020 7:39 pm
same config on V7b2 is working!! now vlan on brige work as expected also with CHR on Hyper-V! :-)
Users browsing this forum: No registered users and 10 guests
