BobCat
adding eoip interface to bridge breaks internet
Sat May 11, 2019 10:01 pm
Good day.
I am running the latest mikrotik x86 routeros within phpvirtualbox
Everything was working fine until recently.
I have interface bridge with ports ether1 , eoip1 , eoip2 etc
The problem is that suddenly i am unable to access the routeros via winbox with ip address.
I can only when using mac method.
But after i disable the eoip ports within bridge interface then sudden everything works again.
It was working fine for 4 days now, only started doing this today.
I have not modified and rules or any settings.
[Emile@Pinachos (Support)] >
[Emile@Pinachos (Support)] > interface bridge port
[Emile@Pinachos (Support)] /interface bridge port> pr
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ether1        bridge1        yes    1     0x80         10                 10       none
 1 XI   weshandelshuis        bridge1        1     0x80         10                 10       none
 2 XI   camproadhouse        bridge1        1     0x80         10                 10       none
 3 I   sxtlte01        bridge1        1     0x80         10                 10       none
[Emile@Pinachos (Support)] /interface bridge port> dis 3
[Emile@Pinachos (Support)] /interface bridge port> /ping 192.168.0.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.0.1                                56  64 0ms
    1 192.168.0.1                                56  64 0ms
    2 192.168.0.1                                56  64 0ms
    3 192.168.0.1                                56  64 0ms
    4 192.168.0.1                                56  64 0ms
    sent=5 received=5 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
 3 XI   sxtlte01        bridge1        1     0x80         10                 10       none
[Emile@Pinachos (Support)] /interface bridge port> en 3
    0 192.168.0.100                              84  64 236ms host unreachable
    1 192.168.0.1                                             timeout
    2 192.168.0.1                                             timeout
    3 192.168.0.1                                             timeout
    4 192.168.0.1                                             timeout
    5 192.168.0.1                                             timeout
    6 192.168.0.1                                             timeout
    7 192.168.0.1                                             timeout
    sent=8 received=0 packet-loss=100%
    sent=3 received=3 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
ovidiu
Re: adding eoip interface to bridge breaks internet
Fri Nov 08, 2019 9:07 pm
I had similar problem and I solve it changing MTU=1500 for the EOIP tunnel
See this post: viewtopic.php?f=2&t=106730&p=759517#p759517
Zacharias
Fri Nov 08, 2019 10:11 pm
Go to your Bridge interface and change the Bridge's MTU to 1500 Byte...
Users browsing this forum: No registered users and 2 guests
