3liswaid
951Ui-2nD MetaRouter
Tue Jun 11, 2019 3:03 pm
Hi i have ,
951Ui-2nD
https://mikrotik.com/product/RB951Ui-2nD
and i can't install a VM due to low storage capacity.
is there any solution to expand it or delete unused packages?
Lifz
Re: 951Ui-2nD MetaRouter
Tue Jun 11, 2019 3:47 pm
No, since this model has SPI flash, MetaRouter is not supported.
3liswaid
Tue Jun 11, 2019 4:19 pm
it supports the Metarouter but i don't have enough space on local storage
3liswaid
Thu Jun 13, 2019 1:12 am
ANY HELP?
Sob
Re: 951Ui-2nD MetaRouter  [SOLVED]
Thu Jun 13, 2019 4:41 am
There's no help. You can either buy some other supported device with larger storage, or you'd need to have really small metarouter. The latter could be theoretically possible if you are assembler guru, but realistically, I don't think there's any chance to create anything useful like this.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
r00t
Thu Jun 13, 2019 3:52 pm
It might be fun exercise to netboot metarouter from network, loading only small PXE client locally...
Users browsing this forum: No registered users and 3 guests
