cdstg
Qemu Agent bug
Wed Oct 09, 2019 2:29 pm
I used the Qemu agent and most things work except the file-write and file-read
It gives me a file handle back like 25 if you use that to read you get
Agent error: Bad file descriptor
Same with write it writes a little eg the buffer but I think the same error is happening that its not using that handle or the handle goes away its weird
I tried a lot of ways using socat and manually doing the commands but it does not work
the same code and manual methods work fine with and agent running on a plain linux machine
I was trying on version 6.44.5 and also the latter versions with the same results
any ideas thanks
Users browsing this forum: No registered users and 3 guests
