alsaidi
how install microtik on vps
Mon Jan 06, 2020 1:19 am
i have vps ubuntu 18.4 from contabo.com . how install microtik on vps .and does when i installed microtik CHR on vps i can use server vps to other job for example install wordpress and other application.
thank you
normis
Re: how install microtik on vps
Mon Jan 06, 2020 10:40 am
You can install RouterOS CHR installation in your Ubuntu. You need some kind of Virtual Machine software in your Ubuntu. Some examples are here:
https://wiki.mikrotik.com/wiki/Manual:C ... nstall_CHR
mariuxmontero29
Tue Jan 07, 2020 10:07 pm
Hello.
As I can see the operation of QoS in a virtual network made with GNS3, Video, VoIP and Data Vlan are used. The problem is the following I am using GNS3 software which allows me to emulate the image of the mikrotik CHR, I use 1. router with the CHR image of the Mikrotik 2 switch, a trunk mode and access mode is used for both switches. The Vlans are working fine, but I don't know how to test QoS on these Vlans, I was thinking about virtualizing on different machines.
Please, if you could help me, thank you!
Users browsing this forum: No registered users and 9 guests
