David1234
CHR 6.46 unable to use API?
Tue Feb 11, 2020 12:45 pm
Hello ,
I have a working server on cloud using v6.46
I'm able to connect to it using winbox
but when I try to connect using API (C# code) I'm getting
"login failure for user admin from x.x.x.x via api"
but when I connect with winbox with the same user\passit's working
I remember there was something about "new api login" from version 6.45, but I can't find it
how can it be?
Sob
Re: CHR 6.46 unable to use API?
Tue Feb 11, 2020 7:22 pm
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
David1234
Wed Feb 12, 2020 10:13 am
OK ,
this is what I look for
Thank you!
Users browsing this forum: No registered users and 5 guests
